December 23, 2004, 22:05
Inlet Temperature Fluctuation in CFX-5.7 LES Mode
I want to know how to treat the inlet temperature fluctuation in the CFX-5.7 LES model. I am calculating the time dependent temperature field of triple jets (41C, 65C, 41C and the three jets have the same velocities 10m/sec, working fluid is air). I choose the turbulent intensity 5%. Then, the calculated results have the physically unrealistic solutions which are much larger than the 65C and much less than 41C. I think the code treats the inlet temperature in KELVIN (K) and specify the inlet temperature fluctuation in terms of KELVIN. So the maximum temperature is (273+65)*1.05=355K(82C) and the minimum temperature is (273+41)*0.95=298K(25C), which are observed in the solutions. These temperatures are definitely physically unrealistic solutions. I want to specify the maximum inlet temperatures like 273+65*1.05=341K, and minimum inlet temperature like 273+41*0.95=312K. How I can do it in the CFX-5.7 LES model? I should carry out my compuatations as soon as possible. Can anyone help me ?
Best regards,
Halim Choi
