December 17, 2004, 00:37 |
details of jet mixing
sir i would like to introduce myself iam swarnalatha doing my final year M.TECH (plant design) in NITT. my doing my project in the topic jet mixing. i have to stimulate in cfx. we have created the geometer of my experimental set up. its a cylindercal tank (28cm dia & 28cm height) .a intet pipe with nozzle at 20cm height & outlet at 4cm from bottom contected to a recirculation pump. i have added the tracer at top liquid surface in my experiment .. how to introduce tracer in this cfx model. tracer is Nacl solution.
kindly reply |
December 19, 2004, 16:36 |
Re: details of jet mixing
Use an additional variable. Glenn Horrocks |
December 20, 2004, 01:16 |
thank u,but i didnot get u.. some one told me to introduce as a stream line.. will it?? have some idea.
December 20, 2004, 16:33 |
Have a think about what is happening in your flow. A streamline is the path a massless particle would follow in a steady state flow. It does not tell you much about mixing. Using a user variable you can tell where there is no tracer, and the amount of tracer when it is present. Glenn Horrocks |
December 21, 2004, 23:50 |
thank i will try..
Display Modes | |
2D Plane Jet Fluent Solution | doug | Main CFD Forum | 11 | February 4, 2019 09:34 |
user subroutine error | CFDUSER | CFX | 2 | December 9, 2006 06:31 |
user defined function | cfduser | CFX | 0 | April 29, 2006 10:58 |
Fluent 5.5. What the differences with fluent 5.3?? | confused | FLUENT | 2 | July 29, 2001 21:58 |
IMPINGING JET ........... HELP!!!!!!!! | Amir Omoumi | Main CFD Forum | 10 | August 30, 1999 22:11 |
