Starting the CFX-solver from the command line |
December 29, 2004, 15:49 |
Hi, everyone,
I am trying to run cfx from command line, this is my command: cfx5solve -def R1.def -ini R1_001.res -double -batch I can get the result, but I don't know how to make solver "interplate initial values onto Def file mesh", which is very simple in cfx-solver manager. There is a check box for this option. |
December 31, 2004, 07:04 |
Re: Starting the CFX-solver from the command line
I know you can re-start using the command line, but like you i have yet to find a flag in the manual which interpolates the results.
January 1, 2005, 20:03 |
Try creating a simple text file with:
EXECUTION CONTROL: RUN DEFINITION: Interpolate Initial Values = Yes END END Then, from the command line cfx5solve -ccl file_above -def .... If the name of the parameter is incorrect, take a look at an output file created from the solver manager where the interpolation was selected.. Have a happy new year.. |
January 3, 2005, 15:59 |
Thanks.
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
viewing cfx post while working on cfx solver manager | HMR | CFX | 5 | March 9, 2011 22:33 |
[ICEM] trouble with mesh quality from ICEM in CFX Solver | escher25 | ANSYS Meshing & Geometry | 0 | February 28, 2011 07:38 |
How to start CFX Solver with an existing parfile | lentschi | CFX | 3 | February 20, 2011 13:31 |
problem in CFX solver about isolated volumes | Yuan | CFX | 2 | August 16, 2004 22:54 |
