January 9, 2005, 21:07 |
ICEMCFD to CFX5.7.1
Hi Does someone use ICEMCFD 5.0 as a mesh generator? When I finished my model in structural hex grid, I want use its output fonction to convert my grid to CFX 5.7 compatible format. But I always can not success doing that. Who can teach me how to do it ?
Gary |
January 9, 2005, 21:52 |
Re: ICEMCFD to CFX5.7.1
Hi Gary,
I am now going with ICEM5.1 and CFX5.7.1 and the hex mesh generation of ICEM works well. I don't know what you problem really is, maybe you should pay some attention to the error message. By the way, ICEM5.1 seems to be better than ICEM5.0. |
January 9, 2005, 23:50 |
Twiti Originally, I installed ICEMCFD 5.1. But I found that ICEMCFD 5.1 can not convert its formats to some CFD solvers like CFDRC, ADINA...; it only can be transferred to ABAQUS, LS-DYNA...So, I removed ICEMCFD5.1 and install 5.0 again. In ICEMCFD 5.0, I can select different solver in "output" tag. While I have selected the solver, I do not know how to set the proper parameters in "BC" tag and "PAR" tag . Following its tutorial, there were always differences between tutorial and what I saw in my case. It's hard to keep practicing more. Anyway, Do you know the relation between the normals of surface and Hex grid formation ? Do I need to reverse each normals of surface toward the volume ?
January 11, 2005, 06:53 |
You should modify shortcut for ICEM CFD 5.1 just add -cfd to the end of command line - it will start cfd version instead of fea (AI Environment). And everything will be OK. (or you can see shortcuts in ICEM 5.0 and modify 5.1 accordingly). Best regards.
January 11, 2005, 20:11 |
Thanks , deLuther .
Gary |
Exporting structured mesh from ICEMCFD to Fluent? | jeevan kumar | FLUENT | 1 | January 23, 2012 12:21 |
Icemcfd 11: Loss of mesh from surface mesh option? | Joe | CFX | 2 | March 26, 2007 19:10 |
a question about icemcfd ddn? | George | CFX | 3 | August 20, 2006 21:08 |
importing mesh from icemc icemcfd 4 to icemcfd 10 | James Willie | CFX | 3 | July 7, 2006 14:19 |
IcemCFD 4CFX-How to fix domain | Ahmed | CFX | 6 | March 9, 2004 19:38 |
