February 8, 2005, 06:41 |
USRBCS
Hi:
I want to do appy this at inlet: (1) IF KSTEP.EQ.0 THEN T(inode,iphase)=X1. BUT (2) IF KSTEP.GT.0 THEN T(inode,iphase)=X2. If I only write (2) in USRBCS and have (1) in command file (fc) would this work...or do I have to write both statements in USRBCS? I hope this makes sense. Thanks in adcance. RK |
February 13, 2005, 00:20 |
Re: USRBCS
Robin,
USRBCS gets called "after" everything is set in the command file, to allow you to overwrite what's been set. You can put the second case in USRBCS to apply only after KSTEP > 0. Please note however that boundary conditions are set using the array VARBCS(IT,INODE,IPHASE) = value Where IT is the equation number for temperature, returned from: CALL GETVAR('USRBCS','T ',IT). Also, don't forget to set IUBCSF = 3 so that USRBCS gets called for changing iteration and/or time step. Otherwise, USRBCS will assume a static boundary condition and only call the routine once. Jeff |
February 23, 2005, 04:10 |
Re: USRBCS
Hi, Following up on Robins request, I guess the difficult part is the wall boundary conditions. I have been trying to implement a stress model at the boundary for sometime now FOR TWO-PHASE TURBULENT FLOWS. Basically, this model has a gradient of velocity in it. However, by using SETWRK AND GRADV routines, I get floating invalid error.
I noticed in the documentation the following under the discussion of GRADV: "Note that, in turbulent flows, the gradient at the wall of the velocity components is stored at the cell centre adjacent to the wall." Can someone help with this? Thanks in advance. Franklin. |
USRBCS in CFX 5 (actually, 5.7.1) | ATS | CFX | 2 | August 24, 2005 12:30 |
Define scalar wall boundary by USRBCS? | windhair | CFX | 2 | November 26, 2003 08:00 |
USRBCS | shalaby Hemdan | CFX | 8 | July 16, 2003 21:05 |
usrbcs for inlet boundary | Jesper Laursen | CFX | 2 | May 31, 2002 16:34 |
USRBCS flag | Alex | CFX | 0 | February 12, 2002 10:41 |
