October 26, 2018, 08:23 |
#21 | ||
Rep Power: 20 |
Also as per my understanding the interface should be exactly same on both the sides? Quote:
October 26, 2018, 08:33 |
#22 | |
Gert-Jan
Rep Power: 27 |
No, not necessary. Certainly, if you have a coarse mesh on either side, it will affect your solution. Therefore, you could perform some tests to check their influence. |
October 26, 2018, 08:40 |
#23 |
Rep Power: 20 |
thanks for your help. I will try this and will share the results.
One more thing. If i include the connecting wall between suction and pressure ports and just consider it as a part of interface on both sides of interface, will it gonna work? |
October 31, 2018, 03:21 |
#24 | |
Rep Power: 20 |
interface.jpg Any idea? |
October 31, 2018, 03:40 |
#25 |
Gert-Jan
Rep Power: 27 |
Turn on the expert parameter?
October 31, 2018, 05:23 |
#26 |
Rep Power: 20 |
Even with frozen Rotor it's not working because I think the pistons are not getting the right motion.
For the mesh motion i have defined 5 local coordinate systems at the interface surface of each piston as seen in the figure1. I set to rotate the local coordinate frame at the same rotational speed so that I can easily define the displacement of each piston in each local coordinate system (e.g. for local coordinate system of piston1 as seen in figure 2) . But when i define the rotational speed of local coordinate system then i can't access this coordinate system under the boundary condition panel as seen in figure 3. In such a case how i can refer the local coordinate system for definition of Mesh displacement? interface1.jpg interface2.jpg interface3.jpg |
October 31, 2018, 10:43 |
#27 |
Rep Power: 20 |
Just a simple question. When I load the mesh in CFX then CFX automatically places Global coordinate system centre at the centre of body as shown by the red dot in the attached figure. centre.jpg
I am asking this because I don't know the location of Global coordinate system and I am just specifying 'Global Y' as rotation axis. |
October 31, 2018, 15:41 |
#28 |
Gert-Jan
Rep Power: 27 |
I know it is possible with immersed solids. I can share an example which is different but contains the similar settings.
I don't know with moving mesh. Maybe there is a limitation on moving mesh in combination with a rotating domain. I doubt it, but if you want to be sure I would ask the Support for an example. |
October 31, 2018, 15:47 |
#29 | |
Gert-Jan
Rep Power: 27 |
I don't understand this. If I am correct, CFX creates the Global Axis on the origin (0,0,0). As a check, you can always create a monitoring point with certain coordinates to find where you are in the geometry. |
October 31, 2018, 16:09 |
#30 |
Rep Power: 143 |
I have use moving mesh and TRS to model rotary sliding valves many times and it works fine for me. But I do not use moving mesh and rotating frames of reference on the same domain. I have a domain either moving mesh or rotating frame of reference, but not both.
November 1, 2018, 11:48 |
#31 | |
Rep Power: 20 |
November 1, 2018, 12:02 |
#32 | |
Rep Power: 20 |
The second option is to define the rotation axis using Two Points Option i.e. Rotation axis from and Rotation axis to...but i am not sure what is meant by this? Do you have any idea or example? |
November 1, 2018, 12:06 |
#33 | |
Rep Power: 20 |
If domain is rotating and i also specify a rotation for local coordinate system then this coordinate system is no more available under the boundary conditions tab as shown in the picture in the above posts. I asked the support guy but he was not sure about it and he said that he will tell me later. |
November 2, 2018, 03:26 |
#34 | ||
Gert-Jan
Rep Power: 27 |
There is also an option to create a coordinate frame based on the normal of a surface. Convenient if you don't know its, center. Remember you can find coordinates using the creation of monitor points. |
November 2, 2018, 03:28 |
#35 | |
Gert-Jan
Rep Power: 27 |
That is why I advised to create a very simple geometry and calculate the movements of all objects without calculating the flow. To first find out how everything behaves and moves like you want. Start simple.......... |
November 2, 2018, 06:21 |
#36 |
Gert-Jan
Rep Power: 27 |
November 2, 2018, 06:27 |
#37 |
Gert-Jan
Rep Power: 27 |
Can't upload it somehow. You can download it here: https://we.tl/t-jk5dTykpvB
November 5, 2018, 09:47 |
#38 |
Rep Power: 20 |
thanks a lot for your reply. I will look at your example. I am facing another problem. The pistons are getting the right movement but the interface side which is on the rotating domain side, is also moving. Although i have defined the 'Mesh Motion' to 'Stationary' on this side of interface but still the mesh is moving. This can be identified by the figures attached with the post. mesh_movement.jpg mesh_movement1.jpg The reason which came to my mind is that it is not a wall but a fluid interface, so the mesh nodes on interface are also moving but not exactly as the pistons. Any idea how i can keep the mesh on this interface as stationary? |
November 5, 2018, 15:12 |
#39 |
Gert-Jan
Rep Power: 27 |
I don't have a lot experience with deforming mesh.
November 5, 2018, 16:31 |
#40 |
Rep Power: 143 |
Please post an image which shows clearly which domains are rotating and which are moving mesh, and for the moving mesh domain clearly show your different boundary patches and the moving mesh boundary conditions you applied to them.
Display Modes | |
Boundary Condition for Pump simulation for Zero Head Condition | Himanshu_Shrivastava | Main CFD Forum | 0 | March 26, 2017 03:25 |
Dynamic simulation of piston | Jaiganesh S | Main CFD Forum | 2 | October 5, 2013 06:45 |
simulation of radial blower - topoSetDict problem | nash | OpenFOAM Pre-Processing | 1 | August 14, 2013 08:26 |
Piston Simulation | helloworld922 | Autodesk Simulation CFD | 1 | September 9, 2012 22:54 |
Centrifugal Pump simulation for radial forces | tareqkh | FLUENT | 0 | February 11, 2012 08:31 |
