CFX Running problem
Like Tree6Likes
  • 1 Post By Gert-Jan
  • 1 Post By ghorrocks
Old   October 26, 2018, 02:54
Default CFX Running problem
Hamda
Hamda is on a distinguished road
I am supposed to model heat transfer between spheres (solid) and fluid (the space). each sphere is a fuel element and generates heat. So I defined an energy source in subdomain in solid.
When in Fluid domain.... Heat transfer; I select "None" or "Isothermal" I can run my case but when I select, "total energy" or "thermal energy" I can't run it.
I think my problem is related to setting of boundary conditions, models in fluid domain and fluid and solid interfaces.
I really appreciate if someone who has experience on this issue, help me.
Thanks
Hamda is offline   Reply With Quote
Old   October 26, 2018, 03:02
Gert-Jan
Gert-Jan will become famous soon enough
Given the problem you should run with Thermal Energy. And it should run fine. Since it doesn't, there is something wrong with the settings. But it is impossible to say what is wrong without more information.
Can you share the output file?
Hamda likes this.
Gert-Jan is offline   Reply With Quote
Old   October 26, 2018, 03:57
Hamda
Thank you for your swift response.The solver failed with a non-zero exit code of : 2
Since I think the problem is related to fluid and interface settings. I provide you with more information about them. Please find the attached files in which there are settings of fluid and solid interface have been shown.
Many thanks
Old   October 26, 2018, 05:27
Please attach your CCL file, not screen shots. Also error codes are useless without context. Please attach your output file for that one.
You have set the non-overlap conditions. These get applied for regions where the the interface does not overlap, and you do not appear to have any of this. Is this what you intended? I suspect not....
Hamda likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   October 26, 2018, 05:55
Hamda
I am sending you my CCL file, please fine the attached file. No I didn't set non- overlap conditions.
Old   October 26, 2018, 06:19
There is nothing obviously wrong after a quick look. You have set Viscous dissipation to On which is almost certainly incorrect, but this probably won't have any significant bad effects so correcting it is unlikely to help much.
Please post your output file and if the run produces a results file an image from the results file. The image should show the results you are getting and why you think the results are wrong.
Hamda likes this.
Old   October 26, 2018, 07:27
Hamda
please find the output file. No I can't run it.
Old   October 26, 2018, 07:36
Gert-Jan
Did you read the output file at all? How obvious do you want the solution to be presented?
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| SYMASS_CS_ELIM : The solver ran out of temporary space while buil- |
| ding a linked list for a domain. Try setting the expert paramete- |
| r "topology estimate factor" to a value greater than 1.0. Values |
| higher than 1.2 should not be necessary. |
Hamda likes this.
Old   October 26, 2018, 08:02
Hamda
| Message: |
Yes you're right. I just had a glance at it and I didn't see that message at the end of the file. Now I can run it. Thank you so much.
Old   October 26, 2018, 08:08
Gert-Jan
Nice to hear. Have fun.
Hamda likes this.
Old   October 26, 2018, 08:10
Gert-Jan
BTW, I saw that you run upwind. Maybe you used that setting while finding a solution. Now I strongly recommend to set it back to High Resolution.
Hamda likes this.
Old   October 26, 2018, 08:38
Hamda
Yes I will do that. But for the first run I make simple my case. My real case is unsteady and I should write some expression.
Many thanks
Error problem while running sadia d lts tutorial kane OpenFOAM Running, Solving & CFD 2 May 26, 2018 03:38
Problem in running coarse mesh(on the other hand fine mesh is running) ashokmoravaneni OpenFOAM 7 July 17, 2017 04:56
Modify SST kw model in CFX Tingyun YIN CFX 6 May 12, 2017 06:44
CFX Solver stopped with error when requested for backup during solver running Mfaizan CFX 40 May 13, 2016 06:50
Numerical oscillations in CFX with water boiling problem. michujo CFX 4 December 16, 2011 09:00
