Changing Time stops
Old   February 21, 2005, 17:19
Default Changing Time stops
Akin
Hello, I am in the middle of a simulation tha seems to be taking ages, can I stop and change the the total time ? or am i stuck
Old   February 22, 2005, 00:04
Default Re: Changing Time stops
Jeff
From the solver manager, you can edit a run in progress (edit button toward the right end of the button row). This fires up the CCL editor for the running job. Change the stop conditions and save the file, exiting the CCL editor.
This works well if it's a steady-state run. Unfortunately, if it's a transient run, I haven't had much luck changing the time steps, total time, or other transient parameters.
Jeff
Old   February 22, 2005, 13:49
CFX5.7User
Use "cfx5stop -dir yourrun.dir" in the command line. See manual for instruction.
Old   February 22, 2005, 15:53
Rui
That command will stop the solver at the end of the present time step. But imagine that you set the simulation Total Time to 30 s and you want to change it to 20 s. Edit Run in Progress seems to not work in transient simulations, so is there any way to change the Total Time ?
Thanks and regards,
Rui
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
calculation diverge after continue to run zhajingjing OpenFOAM 0 April 28, 2010 04:35
[OpenFOAM] How to draw a time changing vector in paraview bigphil ParaView 0 December 5, 2009 09:28
changing time step during a run N Menon CFX 2 May 6, 2002 07:17
unsteady calcs in FLUENT Sanjay Padhiar Main CFD Forum 1 March 31, 1999 12:32
