Problems of convergencia in arrays
Old   February 21, 2005, 15:26
Default Problems of convergencia in arrays
Jussara Zanote
I am simulating the dispersion inside of a set of obstaculos and I am not obtaining to converge my solution in finer meshes
Old   February 21, 2005, 16:24
Default Re: Problems of convergencia in arrays
That is fascinating to hear, but if you are not more specific we cannot help you. If you want us to try to assist please give some more details.
Old   February 21, 2005, 16:54
Jussara Zanote
I work inside with the dispersion of Pollutants of a set of obstaculos. A pen exists that is launched for inside of a set of cubicos obstaculos with a configuration of of seven obstaculos for seven. In this numerical simulation I am calculating the profiles of speed and the concentration of the pollutant in determined points of the configuration, however when I go to test a finer mesh I do not obtain to reach the convergencia of the solution.
Old   February 22, 2005, 16:29
Is your simulation transient or steady state? What differencing scheme are you using? What initial conditions are you using? What is a representative Reynolds number of the flow? What is a representative Mach number of the flow (if it is compressible)?
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
Array problems Malachy FLUENT 2 March 5, 2012 15:11
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Some problems with Star CD Micha Siemens 0 August 6, 2003 13:55
