November 1, 2018, 10:01 |
ansy cfx input script
Konstantinos
Rep Power: 9 |
Hello, Is it possible to import data from specific txt file to ansys cfx pre automaticaly? I want this process to be repeated in every cfx pre update in case of the data in txt being changed. I tried session record, but every time i play this session it keeps the same input data no matter if i change txt data.
November 1, 2018, 16:47 |
Rep Power: 143 |
You might need to run the CFX-Pre/CFX-Solver loop in a batch file. This will allow you to update the session file and txt file when you iterate.
November 7, 2018, 03:36 |
Konstantinos
Rep Power: 9 |
mr ghorrocks, i used backround runwb2 with script. However, i would like to ask you another question. Is it possible and how to enable parallel parametric solving. I mean to solve more than one design point parallel. Can i do this in workbench gui interface? Because my script just opens workbench updates design points and saves workbench in backround.
November 7, 2018, 17:44 |
Rep Power: 143 |
If you are doing it in workbench then use parametric modelling inside workbench. If you are scripting it then do it using the CFX solver stand alone (ie outside of workbench) and then you need to script all the actions directly.
Correct foamfile header for input file with mixed quantities (any version of OF) | deepbandivadekar | OpenFOAM Running, Solving & CFD | 3 | February 15, 2021 05:10 |
CFX re-meshing Script | Rolanddr | CFX | 4 | January 20, 2017 03:23 |
[OpenFOAM] Paraview 3.98 - errors when saving geometry file | pajot | ParaView | 1 | September 28, 2013 10:45 |
Linking input and output variables in CFX | Houman | CFX | 3 | May 14, 2012 18:33 |
ATTENTION! Reliability problems in CFX 5.7 | Joseph | CFX | 14 | April 20, 2010 15:45 |
