algebraic slip model with stirred suspension?
Old   April 15, 2005, 09:10
Default algebraic slip model with stirred suspension?
Manuel Krause
Hello everybody, I simulate a two phase flow in a stirrer where glass particles (200 micrometer) are suspended in water (fixed 5% integral volume fraction). I used to work with the Euler-Euler model (transient simulation), SST turbulence model and the Brucato variation of the Schiller-Naumann drag force model. The particles were represented as dispersed fluid phase. A solid pressure model guaranteed a maximum packing of 60%.
To improve the performance of my simulation Iīd like to use the algebraic slip model (ASM). The ASM will reduce the number of differential equations for the iteration and is implemented in CFX 5.7.1 but the model appears little adaptable. Thus, I canīt define a solid pressure model (necessary for ASM?) just as little as I can implement the Brucato variation. Does anybody know, how to deal with this problem?
k-epsilon model for stirred tanks Parag Shah Main CFD Forum 3 June 22, 2013 15:24
Low Reynolds k-epsilon model YJZ ANSYS 1 August 20, 2010 13:57
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
Implimenting Maxwell's Slip model in Fluent 3D Ravi Duggirala FLUENT 0 January 23, 2006 11:17
Algebraic Turbulence Model for 3D flow Dmitriy Makarov Main CFD Forum 0 June 28, 1999 01:40
