Wall Heat Transfer Plot
Old   April 22, 2005, 04:43
Default Wall Heat Transfer Plot
Paul
Hi everyone,
I need to create a contour plot of the "Wall Heat Transfer Co-efficient" (manually calculated as h = q/(Tw-Tref)). The reference temperature is the temperature at a distance away from the wall.
Is there a way of writing a CEL Expression which will evaluate h with the reference temperature taken from the offset location? The "probe" function allows you to use the Temperature from a particular point, but would only give me one value of Tref for the entire surface, so is not suitable.
Any help would be much appreciated
Cheers
Paul
Syntax errors with Thread Types and Wall Heat Transfer calculation jcespada Fluent UDF and Scheme Programming 2 March 16, 2012 02:23
natural convection mehrdadeng CFX 10 February 25, 2011 05:25
Heat transfer coefficent for the coupled wall jing113cn FLUENT 5 February 24, 2010 03:12
Flow around pipes - heat transfer coefficient on the wall of pipe doodek Main CFD Forum 2 November 23, 2009 08:48
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 6, 2008 23:17
