April 20, 2005, 09:09 |
hexa structured mesh
Having failed to export a hexa mesh from ICEM CFD 5.1 to CFX-pre 5.7.1, I was told it was because CFX couldn't recognize structured mesh, and convertion to unstructured mesh may be necessary before exporting. I wonder if it is the case, if so, how to create structured mesh without using CFX-bulid 5.0.
April 20, 2005, 09:24 |
Re: hexa structured mesh
Hi Phrain,
That is certainly not the case. When you export a mesh from ICEM CFD (any type) to CFX-5, it writes it to a neutral format. Make sure that you choose ICEM CFD as the mesh type in Pre when you import the mesh. Regards, Robin |
April 20, 2005, 09:37 |
Robin,
Many thanks for your response. I did choose ICEM CFD, so did my colleague, we both had the error message displaying as follows: 'Premature end of file found when reading header.' Wonder what that means. Thanks and regards, Phrain. |
April 24, 2005, 05:09 |
Phrain, I hope the following steps would solve ur problem.
1.After creating the structured mesh in icem,go to file-->mesh-->load from blocking,this writes ur structured mesh in unstructured format(hex.uns) 2.Go to output tab,select the solver cfx5,then in the selection form select hex.uns along with ur filename.uns,give ok.This will create a file of icemcfd format itself 3.Go to pre,select icemcfd as the import mesh format,click ok. This should work. Regards Fred |
April 25, 2005, 05:24 |
Fred,
Many thanks for your message. It did work. 80)) Phrain. |
[ICEM] Creation of hexa dominant mesh and prism layer | gnuboard | ANSYS Meshing & Geometry | 7 | January 11, 2018 04:13 |
Mesh motion with Translation & Rotation | Doginal | CFX | 2 | January 12, 2014 06:21 |
Dynamic mesh - structured mesh | mrestrepo30 | FLUENT | 0 | June 3, 2009 15:40 |
How to control Minximum mesh space? | hung | FLUENT | 7 | April 18, 2005 09:38 |
Structured Grid Definition | craig shores | Main CFD Forum | 3 | March 21, 2001 14:48 |
