editing run in progress
Old   April 27, 2005, 09:07
Default editing run in progress
houman
I got error message when changing the timestep in transient simulation:
ERROR #001100279 has occurred in subroutine ErrAction. Message: Dynamic CCL reread is not currently supported for transient simulations. The run will continue without modification.
Can somebody help me in this regard? thanks in advance... houman
Old   April 27, 2005, 18:31
Default Re: editing run in progress
Just as the message says, editting of a transient run in progress is not supported. If you want to change the timestep of a transient run you have to either set it up before using CEL or fortran; or stop the run, make the change and restart.
Adaptive timestepping is coming in CFX 5.8. It should be released in the next few months. Hopefully that should help you.
Old   April 28, 2005, 03:54
houman
Hi Glenn, thanks for your notice. I have another simple question: is it possible to stop a transient run at the e.g. 5th min. (then change the timestep) and restart it from the rest (and not form 0th min), if yes, pls let me know how?
Regards, houman
Old   May 1, 2005, 19:00
Yes, you can do that. As long as your variable initialation is set to "automatic" or "automatic with value" and you use the first run as the initial condition, it will then continue the simulation from where the first one stopped.
Glenn
Old   May 2, 2005, 04:08
houman
Hi Glenn, Thanks for your reply...
stop when I run in parallel Nolwenn OpenFOAM 36 March 21, 2021 04:56
Error trying to run steady-state sonicFoam dancfd OpenFOAM Running, Solving & CFD 2 February 12, 2013 03:15
how to map results from steady state run to tranient case? phsieh2005 OpenFOAM Running, Solving & CFD 2 November 7, 2010 06:20
Restatring run Tim CFX 2 March 3, 2006 11:54
problems with LES run Tim CFX 1 February 27, 2006 07:28
