April 28, 2005, 02:50 |
solidification + advection
Hi all , In the solidification problem, can any one help me how to implement the advection source term of energy equation by using a fortran routine? Indeed, (rho*delta_H*velocity*liquid_fraction) is not a CFX variable. Thank you in advance.
May 6, 2005, 04:01 |
Re: solidification + advection
An example implementation of solidiifcation is available with CFX-support people. Contact them and they wouldbe able to help out in the implementation. Note that you may not need a fortran to implement the solidification model. Only source terms in momentum and energy equations via CEL. Also you need to follow specific convergence strategy (Mass/energy under relaxation). |
May 6, 2005, 19:22 |
Hi, I use CEL for implementation of solidification, bat, this note include the advection terme (gradient.rho*delta_H*liq_frac*velocity). I Think that, this is possible only by fortran subroutine, but I do not know how to do it.
About the solidification? | H.P.LIU | Phoenics | 1 | December 1, 2010 09:49 |
Restart a solidification with previous solidifation data in v9.4 | jk75 | FLOW-3D | 2 | August 28, 2010 21:40 |
Restart for Solidification | atulverma | FLOW-3D | 3 | May 6, 2009 17:40 |
Unbounded advection discretisation | acarey | CFX | 4 | April 26, 2009 19:05 |
Solidification problem: viscosity ratio limited | Deepak | FLUENT | 0 | December 11, 2008 13:08 |
