multiphase problem
Old   May 11, 2005, 06:39
Default multiphase problem
Mike
Hi!
Could i solve such problem?
Separation volume: i have 2 fluids, one is continuous phase, another is dispersed phase in it on the first stage(at the beginning fo the domain) and becomes continuous phase at the end of the domain where the separation completed.
Thanks, Ivan.
Old   May 13, 2005, 03:22
Default Re: multiphase problem
test
Yes,
You need to define both the fluids as continuous and use the mixture model for multiphase flows. This is the advanced option and you may need to program your own models particularly for drag since the only option available for drag law will be drag coefficient
Regards, Test
Complex multiphase melting problem leff CFX 12 March 18, 2014 16:46
Mass conservation in multiphase problem cna FLUENT 6 April 4, 2010 10:16
UDF problem in multiphase model Amir Khodabandeh FLUENT 1 March 13, 2009 08:43
Problem of B.C. in Eulerian multiphase model Derek Jing FLUENT 0 May 12, 2002 11:52
CF4 - need advice on setting up multiphase problem Brett Towler CFX 2 August 18, 2000 16:38
