plot: pressure-time
Old   May 19, 2005, 14:09
Default plot: pressure-time
kein
Hello everybody!
I am working on a twophase flow in a horizontal pipe and I'm having this problem: i have to create a plotressure-time (my simulation is transient)and everytime i am trying to make it, the programm doesn't seem to react, i mean it's doing like it's thinking but i don't get any results... i have to mention that i have already created a polyline, so as to have a locator, but it didn't bring much.what could be wrong?(the rest is ok!)
thanks in advance
Old   May 19, 2005, 14:48
Default Re: plot: pressure-time
Rui
If you want to create a plot pressure-time in CFX Post, you have to select the Chart tab, and chose the Type: Time. Then you have 2 options: 1- You may chose the Method: Point, and chose a variable. CFX-Post will plot the time evolution of the variable at the point you selected. 2- If you chose the Method: Expression, you have to type an expression, or an expression name, and CFX-Post will plot the time evolution of that expression. Note that by doing this, the plot will only include time instants available in CFX-Post. You also have the option of creating monitor points when you define the problem in CFX-Pre, and then you may export the results from CFX-Solver which include all the timesteps.
In CFX-Post you cannot create a transient plot over a polyline (this would be a 3D plot). The only way to do this is to export the results from CFX-Post at different time instants, and use Excel or Matlab, for example, for ceating the plot.
Hope this helps. Regards,
Rui
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
Orifice Plate with a fully developed flow - Problems with convergence jonmec OpenFOAM Running, Solving & CFD 3 July 28, 2011 05:24
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
Hydrostatic pressure in 2-phase flow modeling (long) DS & HB Main CFD Forum 0 January 8, 2000 15:00
