2D mesh by ANSYS Workbench 8.1
Old   April 23, 2005, 07:15
Default 2D mesh by ANSYS Workbench 8.1
Dome
Dear all Gurus
In the Ansys Workbench 8.1 at the generate CFX- mesh part, after the mane of 2D regions were specified and I would like to create the 2D meash. In order to make this 2D mesh, I know that the following procedure must be done first. : Mesh > Options > Meshing Strategy > Chang Advanced Front and Inflation to Extruded 2D mesh.
Unfortunately, I did not see the Options > Meshing Strategy > Chang Advanced Front and Inflation to Extruded 2D mesh, in my Tree view. Where is this procedure? Especially at the step Meshing Strategy, Where is it? or I did something wrong. Please point me the way and give me the comments as well as the suggestion to create 2D mesh.
With the best regards,
Dome.
Old   April 25, 2005, 18:38
Default Re: 2D mesh by ANSYS Workbench 8.1
I have my monitor display set to a high resolution and large fonts. This changes the way some dialog boxes are displayed, and I remember the Extruded 2D mesh combo box only shows one option, so the Extruded 2D mesh option is not visible. The work-around is to use the up and down toggles to flick between the options.
Old   May 5, 2005, 03:02
Sandra
I've been told that the Extruded 2D Mesh Option is NEW for ANSYS 9 Workbench. It is NOT available in ANSYS 8.1 Sorry! I have 8.1 and it doesn't have the Extruded 2D Mesh Option. You aren't missing anything because you don't have it.
Old   May 26, 2005, 11:56
Dome
thank you very much Sandra
Old   June 6, 2005, 06:20
ha
exporting the modified mesh from ansys dogo1234 ANSYS Meshing & Geometry 1 September 5, 2013 11:08
importing mesh from Gambit and other software to ansys workbench mortazavi CFX 12 May 30, 2012 07:38
[Gmsh] 2D Mesh Generation Tutorial for GMSH aeroslacker OpenFOAM Meshing & Mesh Conversion 12 January 19, 2012 03:52
importing mesh from Gambit and other software to ansys workbench mortazavi ANSYS Meshing & Geometry 5 June 6, 2011 11:09
importing mesh to ansys workbench??? mortazavi ANSYS 0 June 1, 2009 05:10
