March 15, 2016, 03:36 |
lpnquery error
Rep Power: 15 |
Dear all,
I have a problem with CHT simulation of power generator. When I run the calculation, even before partitioning I get this error: RUN DEFINITION: Run Mode = Full Solver Input File = CFX.def END SOLVER STEP CONTROL: Runtime Priority = Standard MEMORY CONTROL: Catalogue Size Override = 1.2x Integer Memory Override = 1.5x Memory Allocation Factor = 1.0 Real Memory Override = 1.1x END PARALLEL ENVIRONMENT: Number of Processes = 4 Start Method = Platform MPI Local Parallel Parallel Host List = xwmlsomc0020*4 END END END END Couldn't initialise lpnquery library lpnquery library has not been initialized +--------------------------------------------------------------------+ | An error has occurred in cfx5solve: | | | | C:\Program Files\ANSYS Inc\v150\CFX\bin\winnt-amd64\ccl2flow.exe | | was interrupted by signal HUP (1) | +--------------------------------------------------------------------+ This run of the ANSYS CFX Solver has finished. Does anyone have an idea how to solve this issue? Thank you very much in advance for your comments. Best regards |
March 15, 2016, 07:10 |
Rep Power: 143 |
I have no idea, but as the error occurs during parsing of the CCL I would suggest there is a problem in your CCL or simultion setup.
December 17, 2018, 04:27 |
Maxim
Rep Power: 12 |
I know this is a very old post but I just ran into the same error message and was able to solve it thanks to my CFX support guy. The problem was a German umlaut (üöäß) in a Named Selection in Meshing. CFX Pre does not allow umlauts in its naming scheme but allows already named Patches without a warning. So make sure to not use any special characters in your Named Selections. Best regards, Maxim |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
