April 23, 2005, 07:15 |
2D mesh by ANSYS Workbench 8.1
Dear all Gurus
In the Ansys Workbench 8.1 at the generate CFX- mesh part, after the mane of 2D regions were specified and I would like to create the 2D meash. In order to make this 2D mesh, I know that the following procedure must be done first. : Mesh > Options > Meshing Strategy > Chang Advanced Front and Inflation to Extruded 2D mesh. Unfortunately, I did not see the Options > Meshing Strategy > Chang Advanced Front and Inflation to Extruded 2D mesh, in my Tree view. Where is this procedure? Especially at the step Meshing Strategy, Where is it? or I did something wrong. Please point me the way and give me the comments as well as the suggestion to create 2D mesh. With the best regards, Dome. |
April 25, 2005, 18:38 |
Re: 2D mesh by ANSYS Workbench 8.1
I have my monitor display set to a high resolution and large fonts. This changes the way some dialog boxes are displayed, and I remember the Extruded 2D mesh combo box only shows one option, so the Extruded 2D mesh option is not visible. The work-around is to use the up and down toggles to flick between the options. Glenn Horrocks |
May 5, 2005, 03:02 |
I've been told that the Extruded 2D Mesh Option is NEW for ANSYS 9 Workbench. It is NOT available in ANSYS 8.1 Sorry! I have 8.1 and it doesn't have the Extruded 2D Mesh Option. You aren't missing anything because you don't have it.
May 26, 2005, 11:56 |
thank you very much Sandra
June 6, 2005, 06:20 |
exporting the modified mesh from ansys | dogo1234 | ANSYS Meshing & Geometry | 1 | September 5, 2013 11:08 |
importing mesh from Gambit and other software to ansys workbench | mortazavi | CFX | 12 | May 30, 2012 07:38 |
[Gmsh] 2D Mesh Generation Tutorial for GMSH | aeroslacker | OpenFOAM Meshing & Mesh Conversion | 12 | January 19, 2012 03:52 |
importing mesh from Gambit and other software to ansys workbench | mortazavi | ANSYS Meshing & Geometry | 5 | June 6, 2011 11:09 |
importing mesh to ansys workbench??? | mortazavi | ANSYS | 0 | June 1, 2009 05:10 |
