December 27, 2018, 03:33 |
error ccl2flow
hi every body
I want to solve a transient solid domain with a heat transfer coefficient which is extracted from a modified steady conjugate model. unfortunately in the solver I receive the following error : couldn't initialise openquery library ccl2flow: *internal error 1* message: no namemap in definition file context: load_namemap() is there any idea about this error??? look forward for yours comments. thanks |
December 27, 2018, 04:22 |
Rep Power: 143 |
It means you are using some invalid CCL. If you cannot work out what is invalid about it then attach your CCL to the forum thread.
January 6, 2019, 13:45 |
#3 | |
Hi all I found cause of the error in ccl! in pre-cfx I imported a huge table that cleaning that table and import a smaller one solved the problem. by the way is there any way to extend the limit bound and solve problem directly? |
January 6, 2019, 17:38 |
Rep Power: 143 |
Have a look in the command line options for the solver. I think there are some options for CCL parsing.
