February 23, 2016, 08:53 |
Error reported by IO module
Hossein
Rep Power: 10 |
Hello everybody,
I tried to launch an unsteady simulation with initial value on a cluster by cfx161. but it didn't run and crushed with the following error massage: Do you know why it says: "file is corrupt" Thanks hhm747 An error has occurred in cfx5solve: Error reported by IO module: recreate_indextable: warning: truncated (or bad) index data at end of file while rebuilding index, file is corrupt but probably recoverable, continuing. [1172197824 + 45386 > 1172242432] An error has occurred in cfx5solve: Error reported by : write_index: fwrite failed writing format: Bad file descriptor An error has occurred in cfx5solve: Error reported by IO module: iif_flush: write_index failed An error has occurred in cfx5solve: Error reported by IO module: cfxwriteString: (fputs failed) syserr:: Bad file descriptor |
July 14, 2016, 11:17 |
#2 | |
Maxim
Rep Power: 12 |
I just ran into the same problem and it's driving me crazy. I only have 3 out of your 4 errors:
July 18, 2016, 06:55 |
Maxim
Rep Power: 12 |
I reinstalled CFX 17.1, started the job via command line with a different initial condition file and now the error is gone.
My guess is that it was caused by my *.res file that I wanted to use as initial condition. Will report back if something changes. |
December 28, 2018, 10:10 |
jiaji lu
Rep Power: 8 |
Have you solved the probelm? What's th reason?
January 2, 2019, 02:36 |
Maxim
Rep Power: 12 |
cfx 16.2, hpc cluster, unsteady |
PEM electrolyzer module | A CFD free user | FLUENT | 1 | December 31, 2022 17:16 |
Conduction and Convection Thermal Analysis of a PV Module | firestone9x | ANSYS | 0 | February 19, 2016 08:26 |
[OpenFOAM] Annoying issue of automatic "Rescale to Data Range " with paraFoam/paraview 3.12 | keepfit | ParaView | 60 | September 18, 2013 03:23 |
Can someone PLEASE document the development version installation | bernd | OpenFOAM Installation | 76 | November 14, 2008 21:51 |
Lamboot trouble | r2d2 | OpenFOAM Installation | 4 | October 17, 2005 04:27 |
