June 18, 2005, 09:42 |
ICEM tin file
Hello everybody,
i've merged 4 tin files to one geometrie and i've deleted some curves points and surface. After saving the new merged tin file the size is nearly 200 mb allhough each of the 4 tin file only have 10 mb. e.g. i've although taken the merged file and have deleted everything apart from 1 curve. And the amazing result after saving is: 201 mb for one curve!! Could someone tell me, what's going on here? |
June 19, 2005, 06:11 |
Re: ICEM tin file
Are you sure you deleted the curves and didn't just make them dormant? Make sure the delete permanently box is checked on the delete curve menu.
June 21, 2005, 02:39 |
Re: ICEM tin file
I don't have a "delete curve menu" under the classic surface!
June 21, 2005, 17:22 |
Re: ICEM tin file
You could also open the tetin file in a text editor to see what's in there. If you see a lot of things with DORMANT in the definition - that's where they are. In the new Interface you have the Delete Permanent option for deleting curves, but not in the old interface.
1.7.x Environment Variables on Linux 10.04 | rasma | OpenFOAM Installation | 9 | July 30, 2010 04:43 |
Installation of OpenFOAM-1.6 on Ubuntu 9.10 | marval | OpenFOAM Installation | 2 | March 17, 2010 08:33 |
[OpenFOAM] ParaView 33 canbt open OpenFoam file | hariya03 | ParaView | 7 | September 25, 2008 17:33 |
DxFoam reader update | hjasak | OpenFOAM Post-Processing | 69 | April 24, 2008 01:24 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
