How to show more the one blade in CFX Post
Old   January 11, 2019, 10:52
Default How to show more the one blade in CFX Post
DDG
DDG is on a distinguished road
Hi everybody, I was trying to plot some contour showing more than then one blade, as in the image attached, but I wasn't successful.
How is it possible to obtain such a contour?
DDG is offline   Reply With Quote
Old   January 11, 2019, 11:19
Opaque is on a distinguished road
In CFD-Post, double click on the Domain for the blade. Once the panel is open, select the View tab, and you will see the options to replicate the domain
If you are post-processing a transient blade row results file with Fourier data compression, you can use the "Data Instancing" tab to replicate not only graphically, but timewise as well.
Hope the above helps,
Opaque is offline   Reply With Quote
Old   January 12, 2019, 08:25
DDG
it worked, thanks a lot!
Trackbacks are On
Cfx post Aye Mya Moh CFX 2 February 19, 2018 04:14
defining a blade with mesh motion in cfx nhlstd CFX 1 August 6, 2017 06:48
Heat Release in CFX Post kapopadu CFX 0 April 12, 2013 07:33
[ICEM] Blade meshing in ICEM CFX pol84 ANSYS Meshing & Geometry 3 August 5, 2010 17:19
CFX Post export problem jeff_F CFX 0 August 17, 2009 21:25
