CFX set up about Radial turbine.
Like Tree1Likes
  • 1 Post By ghorrocks
Old   January 21, 2019, 23:45
Unhappy CFX set up about Radial turbine.
XUE CHUANZHI
xcz2017 is on a distinguished road
I am using cfx to analyze a radial turbine, but the result is always a problem, please help me look at my problem.
xcz2017 is offline   Reply With Quote
Old   January 22, 2019, 00:04
Yes, we can help you. But you need to tell us what you are trying to do first.
https://www.cfd-online.com/Wiki/Ansy...ible_answer.3F
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   January 22, 2019, 02:33
XUE CHUANZHI
Is there a problem with my settings?
Old   January 22, 2019, 02:37
XUE CHUANZHI
This is my setup process. Please help me see if there is a problem?
Old   January 22, 2019, 03:10
Screen dumps of CFX-Pre are not very useful. Please attach:
* Your output file
* an image of the flow you are getting
* an image showing what you expect to get
* an explanation of what the problem you are getting is.
Old   January 22, 2019, 07:32
XUE CHUANZHI
Turboexpander
GAS: Helium
Inlet :Temperature(40.012K) Static pressure 9.6 bar
Outlet: Flow rate(17.5g/s)
I want to simulate the efficiency of the rotor expander.
My calculations always don't converge. Can I use the ideal helium gas as the flowing gas?
Old   January 22, 2019, 16:43
Not converged: See FAQ https://www.cfd-online.com/Wiki/Ansy...gence_criteria
Can you use Helium? Yes, you can use any fluid you like.
xcz2017 likes this.
Old   January 23, 2019, 21:37
XUE CHUANZHI
Why the temperatures and pressures rise during the expansion process? Shouldn't it be a continuous decline?
Old   January 23, 2019, 22:01
I have no idea. When faced with an unexpected result you should check what you are doing, do a validation and verification of your results to ensure your simulation is accurate and if all that still says the unexpected result is present then start thinking about whether you have learnt something new.
Cfx results v/s experimental in radial turbine ameya.vjti CFX 5 March 20, 2016 08:36
CFD analysis on wind turbine rotor Ken (Wind Turbine CFD Super Rookie) Main CFD Forum 45 February 9, 2016 14:07
Question on running CFX simulations in workbench parameter set table Anna Tian CFX 0 September 20, 2014 01:51
Gas turbine in CFX rahat69 CFX 4 April 11, 2014 23:44
[ICEM] further refinment - Radial turbine Far ANSYS Meshing & Geometry 14 March 19, 2014 08:12
