add RULES to the CFX-solver files
Old   January 23, 2019, 07:13
Default add RULES to the CFX-solver files
Yan Wang
W.Yan is on a distinguished road
I want to add the following lines in my CCL files:
RULES:
PARAMETER: Kinematic Diffusivity
Dependency Line = ANY
END
END
I have tried to add the lines at the end of the command editor of the solver in the CFX-Pre. however, there was nothing changed when I clicked the process. Also, I tried to click "edit CFX-solver files" in the Solver Manager. I can see LIBRARY and FLOW without RULES under the Root.
Can anyone tell me how to add RULES to solver files. I have been confused for several weeks. Thanks for your help.
W.Yan is offline   Reply With Quote
Old   January 23, 2019, 08:51
Opaque will become famous soon enough
Local rules are usually added at run time in the command line. Say you stored such rules into MyRules.ccl, you then start the simulation by
cfx5solve -def .... -ccl MyRules.ccl ...
You will see the rules listed in the output file.
Alternatively, you can extract the command file from the specific simulation, add the rules section, insert the commands back and run the simulation
cfx5cmds -def ... -ccl MyCommands.ccl -read
Edit MyCommands.ccl, and add
RULES:
END
LIBRARY:
END
FLOW:
END
cfx5cmds -def ... -ccl MyCommands.ccl -write
cfx5solve -def ...
Either way, it should work.
Opaque is offline   Reply With Quote
Old   January 23, 2019, 23:05
Yan Wang
thanks for your reply. What I use is the Fluid Flow(CFD) in the Workbence, and I meet some trouble to open the command line. By the way, Does the "...." in the reply means the direction of the file?
Last edited by W.Yan; January 24, 2019 at 00:21. Reason: I have solved the problem
Old   January 24, 2019, 10:17
... means whatever goes there, i.e. fill the blanks.
Hope you are able to add your local rules.
PEMFC model with FLUENT brahimchoice FLUENT 22 April 19, 2020 15:44
[ANSYS Meshing] Help with element size sandri_92 ANSYS Meshing & Geometry 14 November 14, 2018 07:54
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 00:01
CFX Solver Reynolds Number haider760 CFX 2 March 4, 2012 22:05
CFX 5.5 Roued CFX 1 October 2, 2001 16:49
