a problem about interface setting
Old   January 28, 2019, 03:33
Default a problem about interface setting
Jiacheng Wang
whyjackeyson is on a distinguished road
Dear everyone. For I'm doing a simulation with two components using the continuity source. Thus, I have to define a constraint with one component. However, for I use a multi-block meshing for my model, some interfaces exist. In the setting page for interface boundary details, I can only find the component except for the constraint component. Therefore, the calculation went wrong and I can not get the result I want. What should I do to solve this?
I think it was caused by the interface setting, for I can get a satisfying result with a default meshing in software, which won't bring the interface. Thanks a lot.
whyjackeyson is offline   Reply With Quote
Old   January 28, 2019, 05:14
Please post your output file, an image of your geometry and mesh and the results you are getting - please explain why the results are wrong.
Post these as attachments to the post, please do not link to third party download sites.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   January 28, 2019, 09:06
Jiacheng Wang
The variable composition mixture I chose was C2H6O and water gas mixture and I have define the C2H6O component as constraint. However, in the interface setting, it only has water component but do not have the constraint component.
Old   January 28, 2019, 13:03
Gert-Jan
Gert-Jan will become famous soon enough
What do you want to do with the information of the constraint component on the interface?
In principle, CFX solves an equation for the massfraction of water. The massfraction of the contraint is (1 - masssfraction of water). So, if CFX knows one of them, it automnatically knows the other. Otherwise, it becomes overspecified.
In otherwords, your constraint is known, but 'hidden'.
Gert-Jan is offline   Reply With Quote
Old   January 28, 2019, 13:06
Opaque will become famous soon enough
Could you please post a snapshot of the "interface" you are referring to?
Opaque is offline   Reply With Quote
Old   January 28, 2019, 22:07
Jiacheng Wang
Many thanks for your explanation. Actually, I was unable to fully understand or describe the problem I met. I just met something strange, which was caused by interface I thought.
At first, I have done the meshing automatically with tetrahedral mesh, and I could get a satisfying result.
However, when I just used the multi-block method to finish the meshing (only change the mesh to be structural grids with same model and same cfx setting), the result didn't convergence and not good.
For I just used the hexa grids instead of tetra grids with three blocks, something might go wrong in interface. However, I still can not know why and really confused.
Old   January 29, 2019, 01:01
Your tet mesh is way too coarse to give any meaningful results. You appear to only have 2 elements through the thickness of your device.
Your hex mesh is approaching the resolution where it might work. With all those sharp angles and corners it is going to have lots of big separations and therefore is likely to be tricky to converge. Have you read the FAQ on this? https://www.cfd-online.com/Wiki/Ansy...gence_criteria
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 07:30
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 01:44
Problem with porous flow at multi-material interface with large permeability diff. Hisham OpenFOAM Programming & Development 1 June 3, 2016 10:51
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 08:44
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
