how to use fluid fluid interface
Old   July 13, 2005, 14:08
Default how to use fluid fluid interface
Beno
Hi!
I am having problems with seting up a simulation with a rotating difussor. The geometry is simple stationary cylinder and at the end of it a rotating diffusor. I created two meshes and imported them into cfx. Between the meshes there is a fluid fluid interface. If I use Stzage as the interface model I get the following error:
" ERROR #555000001 has occurred in subroutine SRF_CORRECT.
GGI intersection error: The theta extent is too small on
Domain Interface: FFinterfejs
Please examine your domain interface and look for the following:
1) surface with more than 360 degrees of revolution
2) surface intersects R=0
3) surface has faces normal AND parallel to the rotation axis
Change Transformation Type to None instead of Automatic in the
solver command file if any of the 3 situations apply. "
What does that mean? Can I even use stage model?
Should the type of the domain interface be fluid fluid or interface?
If the type periodic what does rotation or translation actually mean?
Thx in advance!
Boundary conditions at Fluid Solid interface (CHT) michelle CFX 1 April 21, 2008 04:06
BC at the interface of the fluid and solid manohar Siemens 3 April 8, 2005 11:34
interface between porous and fluid rajesh kumar FLUENT 5 October 22, 2004 11:10
access to variables at interface of porous media? Mazyar FLUENT 0 October 10, 2003 14:59
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
