July 15, 2005, 16:57 |
output eq residuals
Hi, Guys
In the help file, it was said: 'setting the Expert Parameter output eq residuals = true (set on the Expert Parameters: I/O Control panel in CFX-Pre)'. However, I can't find this option in that panel. If I define this with CCL, it shows an error message like: "The parameter "output eq residuals in "/FLOW/EXPERT PARAMETERS" has the value "ture". This does not match any of the allowed values: "t, f"." Could you please tell me what's wrong with my cfx-pre? Regards! Phil |
July 15, 2005, 22:22 |
Re: output eq residuals
What version are you using? CFX-5.6 or 5.7.x?
In either case, the message says the only valid values are t or f, you are typing "ture or true" which is invalid.. Just type t for true, or f for false.. Good luck |
July 16, 2005, 10:40 |
ture? typing error? have you tried "t" or "f"?
[Tutorials] Tutorial of how to plot residuals ! | wolle1982 | OpenFOAM Community Contributions | 171 | February 20, 2024 02:55 |
How to visualize Output Equation Residuals in CFD Post | rubin4ik | CFX | 2 | June 22, 2011 06:37 |
Questions about data output | aki_yafuji | OpenFOAM Running, Solving & CFD | 3 | September 9, 2010 01:59 |
lift and drag on ship superstructures | vaina74 | OpenFOAM Running, Solving & CFD | 3 | June 8, 2010 12:30 |
Convergence - scaled vs unscaled residuals | HS | FLUENT | 1 | November 7, 2005 05:45 |
