parallel run with CFX-4
Old   August 2, 2005, 09:25
Default parallel run with CFX-4
amu
I want to do a parallel run with CFX-4. I tried with "parsolve4 -rel 4.4dp -enviro 01 -c m01.fc -f m01.f -geo m01.geo -nprcs 2" and got the message to set the patch memory factor to 1.16. I tried with a meshimport configuration file but this failed. Does anybody know what to do?
Amu
Old   August 8, 2005, 19:07
Default Re: parallel run with CFX-4
Jeff
In your command file, set up the patch workspace to a larger number than the default. The error message in the output file should be telling you how much is required. Look in the command listing at the end of the manual to see how to set up the workspace values.
Jeff
Core usage on CFX parallel processing alterego CFX 6 December 21, 2011 05:45
problem in parallel run in Workbench Mina_Shahi CFX 0 September 8, 2011 11:27
Parallel run in fluent for multiphase flow apurv FLUENT 2 August 3, 2011 19:44
CFX - Parallel Problems CFX User CFX 0 November 1, 2004 18:12
postpressing a parallel run: merge partitions? jx FLUENT 3 November 3, 2003 10:58
