An error occured - simulation of blower
Old   August 5, 2005, 00:49
Default An error occured - simulation of blower
Rashmi
Dear all,
I m doing a blower project simulation in CFX and i m facing some problem in solver ,an error has occurred
ERROR #001100279 has occurred in subroutine ErrAction. Message: ****** FATAL ERROR ****** Finite pitch angle gap could not be found
Could anyone plz help me for this issue checked the boundary condition...everything is fine
i want an immediate reply Regards Rashmi V
Old   August 5, 2005, 01:35
Default Re: An error occured - simulation of blower
just curious
what were you blowing.
Old   August 5, 2005, 02:40
test
Hi Rashmi,
I think there is a more polite way of asking for help rather then sating that you want help immediately.
Well I suppose that you are using Multiple frames of references. The domain which is rotating should have a small patch which will not rotate. Usually this is the shaft. I suppose that you have not modelled it. Any turbo experts around here would be able to help you precisely.
Regards, test
Old   August 5, 2005, 04:28
Rashmi
i have modeled the shaft hole also i m trying to reduce the mesh size in the sense coarsen the mesh.....and solve it.
thank you for ur immediate response i think i m quite polite in asking the queries ok if anything wrong plz forgive me.
may be i m in hurry and so i may have written like that
regards Rashmi v Rao
root blower simulation carno FLUENT 4 May 21, 2015 17:47
Simulation of a complex wing in solidworks flow simulation niels1900 FloEFD, FloWorks & FloTHERM 6 April 20, 2011 10:44
GUI crash and simulation engine still running RPJones FLOW-3D 2 November 9, 2010 08:18
velocity profile export from a simulation onto another sudhirlv STAR-CCM+ 1 September 12, 2010 18:57
strange simulation error Ralf Schmidt FLUENT 2 May 4, 2007 13:02
