One question about the cfx 5 best practices
Old   August 17, 2005, 00:11
Default One question about the cfx 5 best practices
John
Hello, everyone
In cfx best practices for multiphase flow , I found following tips:
"Convergence Tips: Sometimes, physical instabilities (such as recirculation zones) can result in slow or stalled convergence. In these cases, you can still obtain an indicator of convergence for a global quantity by creating a monitor point at some point in the domain. As a result, you can determine whether values for selected global quantities (such as gas hold-up) are meaningful."
My english is just not good enough to help me understanding above tip. When I do a multiphase modelling, does above mean that no matter the convergence criteria are met or not, I can always say the simulation is converged if the selected global quantities (such as gas hold-up) at the monitoring points become stable?
Do I understand that correctly?
Thanks for your comments.
Regards!
John
Old   August 18, 2005, 17:44
Default Re: One question about the cfx 5 best practices
John
The tips can be found in Page 145 of "CFX-5 Best Practices Guide for Multiphase"
Hope sombody can give explainations.
Thanks!
Old   August 18, 2005, 18:30
No, if the values at a specific point have converged then you cannot then assume the whole simulation is converged. Other areas of the flow may not yet have converged.
Also, make sure you know the difference between a converged solution and an accurate solution. It is very easy to get a converged solution with a coarse mesh and upwind differencing, but it will not be accurate.
Regards, Glenn Horrocks
Old   August 18, 2005, 18:39
John
Thanks Glenn for your comments. I understand and agree what you said. But could you please explain the tips shown in CFX best practise. What does it exactly mean?
I still fell confused about that.
Thanks and best regards!
John
question about governing equation in CFX using rotating/non rotating reference frame rystokes CFX 0 January 12, 2010 06:14
question about how to define diffusion coefficient in CFX rystokes CFX 0 December 12, 2009 05:32
CFX 11 Post question DAK565656 CFX 0 October 2, 2008 10:17
ICEM -CFX a basic question Al Mazdeh CFX 2 April 5, 2008 11:51
Question about the shock wave in CFX software nucharin Main CFD Forum 1 January 25, 2005 08:26
