March 5, 2019, 16:37 |
Low Reynolds NACA 0012 validation
Rep Power: 7 |
Hi everyone,
I am modelling a NACA 0012 at 1.15 m/s, chord length = 1 m, 3 deg AoA, through air at 20 deg c and Re = 7000. Using the SST turbulence model, I have obtained values for lift and drag coefficient being approx Cl = 0.13 and Cd = 0.015. I am struggling to find validation for such a low Reynolds number, so I was wondering: would anyone be able to inform me if these values are accurate for this low Reynolds number? Thank you in advance! Last edited by 35matt215; March 25, 2019 at 17:56. |
March 5, 2019, 18:19 |
Rep Power: 143 |
Didn't I post a link to a massive database of results for low Re airfoils? Why are you asking again?
If you can't find your exact airfoil in the database then just choose one which is close and model that as a validation. By the way - I suspect that the airfoil at this Re is not turbulent. It will be either laminar, or transitions to turbulence mid-chord. That means you should be using a laminar flow model, or maybe SST with the turbulence transition model.
March 5, 2019, 18:40 |
Rep Power: 7 |
Thank you for your reply.
Yes you did post that but I could not find the exact one and was not sure but now it is clear, so thank you for clarification. I did try to run it as laminar but the Cl and Cd were not stable and RMS residuals did not converge and it seemed to converge quite well with SST. I have also tried the Gamma Theta SST model but it also did not converge too well however, I will play around with that further. Thank you again. |
March 5, 2019, 18:43 |
Rep Power: 143 |
You select the physics models based on what the physics actually are, not what converges easily.
March 17, 2019, 08:58 |
Rep Power: 7 |
I ran transitional turbulence model and seem to be getting quite good results when compared to published data.
I noticed there seems to be a laminar separation bubble that occurs near the trailing edge of the lower surface of the airfoil. However from reading papers, it seems that the separation bubble normally occurs at the top surface of the airfoil. Can anyone maybe offer an explanation as to why I am getting this separation bubble on the bottom surface of the airfoil? Thanks. |
March 17, 2019, 09:17 |
#6 | |
Oskar
Rep Power: 10 |
Dear Matt Could You possibly share the case? EDIT: I am sorry. I thought it was an OPENFoam sub-forum.
How to set two stroke engine with scavenging? Salome, sliding interface and "Zero length edge detected." Last edited by sheaker; March 18, 2019 at 01:50. |
March 17, 2019, 09:30 |
Rep Power: 7 |
Please see attached the images of this.
March 17, 2019, 17:55 |
Rep Power: 143 |
It is because you are using a low angle of attack. Increase the AOA and the separation bubble will move to the top face.
March 17, 2019, 18:31 |
#9 |
Rep Power: 7 |
Thanks for replying.
I increased the AOA and it occurred on the top surface as you said. Is this definitely a separation bubble and not recirculation? Is it okay if this 'bubble' occurs on the bottom surface? Thank you. |
March 17, 2019, 23:12 |
#10 |
Rep Power: 143 |
Separation bubbles and recirculations are the same thing. Just laminar separation bubbles are small, linked to the transition from laminar to turbulent flow and the flow generally reattaches afterwards. Recirculations are typically larger features and often do not re-attach but stay separated for the entire chord.
But there is no clear distinction between the two, large separation bubbles and small recirculations are the same thing.
Display Modes | |
how to use k-omega low reynolds number in phoenics? | wilcox | Phoenics | 1 | February 4, 2020 13:10 |
High reynolds number model and a low reynolds number model | Ieg1995 | Main CFD Forum | 3 | June 18, 2017 14:18 |
Low Reynolds 2D Airfoil simulation | imoldschool | FLUENT | 0 | December 23, 2016 16:38 |
Naca 0012 validation, Cd value is too high. | Peter88 | OpenFOAM | 4 | January 21, 2014 17:10 |
naca 0012 validation case: wrong Cd | vaina74 | OpenFOAM Running, Solving & CFD | 5 | July 15, 2011 12:50 |
