how to use turboGrid to generate full Fan's mesh
Old   September 8, 2005, 16:10
Default how to use turboGrid to generate full Fan's mesh
go
I understand the TurboGrid can generate a single blade mesh. How to generate full Fan's mesh. Thanks
Old   September 9, 2005, 08:02
Default Re: how to use turboGrid to generate full Fan's me
gwang
You don't need to generate mesh for a full fan TurboGrid. What you need is just a mesh for one single passage. After you import this single passage mesh into CFX-Pre, you can copy it to a full fan mesh. By the way, you need to glue those copies together.
Old   September 9, 2005, 13:45
go
Could you show me how to glue them. Thanks
Old   September 9, 2005, 15:46
gwang
You can find all the information in "Rotation Transformation" under "Mesh Transformation Editor" section of CFX mannual.
Old   September 15, 2005, 15:48
go
How to deal with Periodic face. Thanks
Old   September 15, 2005, 21:39
longbow
When you glue those copies together, there will be no interfaces between them. Periodic surfaces exist only when you just model several blade passages. For a full fan, there should be no periodic surfaces.
Old   September 16, 2005, 09:40
go
Thanks longbow. I would like to know how to deal with Periodic surfance. Do you have any idea?
Old   September 16, 2005, 18:07
longbow
In order for people to help you, you probably need to give a little more information on what you want to do and what's problem you are facing.
[snappyHexMesh] SnappyHexMesh for internal Flow vishwa OpenFOAM Meshing & Mesh Conversion 24 June 27, 2016 08:54
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
unstructured vs. structured grids Frank Muldoon Main CFD Forum 1 January 5, 1999 10:09
