[Sponsors] | |||||
Iljar Dickhof
Rep Power: 8 ![]() |
Hello experts,
I'm trying to model a centrifugal impeller with stator blades (see image). I've read you can reduce calculation time with the use of symmetry. Properties model: Impeller = 5 blades Stator blades = 35 Pitch change = 1 (Frozen rotor interface) In my model I only used 72 degrees of the full model (1 impeller blade and 7 stator blades. My question is as follows: How do I model the impeller with the use of symmetry? If I use symmetry on the faces it will just mirror the component so I need a different commando. Thanks in advance. Greetings, Iljar Dickhof |
Rep Power: 146 ![]() ![]() ![]() ![]() |
I think you will find that you use rotational periodic boundaries, not symmetry.
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| View factor radiation model. Symmetry boundaries verification.. | Dimoon | OpenFOAM Running, Solving & CFD | 12 | April 6, 2021 04:38 |
| Values to consider in a symmetry model | JJ Wey | FLUENT | 0 | December 1, 2015 11:30 |
| Superlinear speedup in OpenFOAM 13 | msrinath80 | OpenFOAM Running, Solving & CFD | 18 | March 3, 2015 06:36 |
| manualInjection model in sprayFoam | Mentalo | OpenFOAM Running, Solving & CFD | 1 | April 2, 2014 10:29 |
| [ICEM] Blocking and Symmetry | BrolY | ANSYS Meshing & Geometry | 32 | August 24, 2012 04:13 |
