Error while setting up porous material.
Old   October 7, 2005, 02:13
Default Error while setting up porous material.
Kiddo
Hi,all
system:Linux, CFX571
problem: As I run a porous simulation with fan( a momentum source), it shows error message after 1st iteration:
<font color=green size=2>
| ERROR #001100279 has occurred in subroutine ErrAction. |
| Message: |
| Subsystem zone not found in SYMASS_ZONE </font>
But as I cancel the porous setting(<font color=blue> note: the model and cfx_pre file are the same as previous except the porous subdomain deleted</font>), then it will be OK .
Does anybody know why?
Old   October 10, 2005, 10:42
Default solved!
Kiddo
It's due to nature of CFX571, nothing to do with the setup and model. Because I put it into CFX10 , and it's ok now !
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Cells with t below lower limit Purushothama Siemens 2 May 31, 2010 21:58
Warning 097- AB Siemens 6 November 15, 2004 04:41
