cfx does not give time steps in cfxpost.why.urgent |
November 21, 2005, 04:21 |
HI i have done transient analysis of a silencer.I have given total time as 0.15 seconds.I have taken 10 time steps.so time steps=0.015sec has been given.In static analysis it have been done 75 itretions.so it is finishing with 85 iterations.Now when i am post procesing results it gives only one time steps as final.Actually it should give 10 times steps from 0 to 0.15 sec.So why it has been happened?pls answer.Actually once in cfx 5.6 i have solved this it has shown me 10 time steps, but when i have taken in cfx 10 it is not showing .why it has been happened?i have also increased time steps from 10 to 75,but same thing has been happened?any body knows this.
My second query is that i want to visulize that velocity vectors are moving thru this domain.In earlier in which 10 time steps have been achieved in post process i have found that it has not given it in animation.so suppose i want to see that how velocity vectors are movind inside domain i.e. how flow is going then what should i do? |
November 21, 2005, 06:55 |
Re: cfx does not give time steps in cfxpost.why.ur
Are you sure you actually asked CFX to output the transient results? If you don't specify this, you will only be given the results from the last time step. James
November 23, 2005, 23:06 |
thanks james.I have not given transient results.After ur info i have got it.
Extrusion with OpenFoam problem No. Iterations 0 | Lord Kelvin | OpenFOAM Running, Solving & CFD | 8 | March 28, 2016 11:08 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 05:24 |
Full pipe 3D using icoFoam | cyberbrain | OpenFOAM | 4 | March 16, 2011 09:20 |
CHT. Cooled blade. Different time steps. | Georg | CFX | 4 | December 26, 2008 08:26 |
Modeling in micron scale using icoFoam | m9819348 | OpenFOAM Running, Solving & CFD | 7 | October 27, 2007 00:36 |
