November 11, 2005, 05:21 |
ANSYS license message
I am using CFX 5.7.1 and the license is due to expire in 30days. Hence everytime I open any of CFX products, an ANSYS license message pops up, stating that the license is due to expire in ...days. The application will only start once I hit the OK button. Now I need to use the solver in batch mode and this wont start until I hit the OK button. The first run will go through as I am present, but what about the others when I am not. Any methods to avoid this message apart from getting the new license? Regards, Santhosh |
November 11, 2005, 17:35 |
Re: ANSYS license message
Yeah, these messages occur only in M$-Windows. That might exist (at least it should exist) some environment variable that controls such annoying messages but I'm also interested in that.
S.W. |
November 21, 2005, 12:25 |
if you have a little experience in programming you can build a small program that periodically looks for Ansys license popup windows and sends them a closure message (you just have to set a timer and to check the names of open windows). Since I don't have Administrator privileges on my computer, I couldn't find an easier way to get rid of those messages. I hope you'll find it useful... ciao |
November 22, 2005, 00:25 |
Thanks,
This problem was solved with the help of Tech Support, just need to add an environment variable and that would get you through to 7 days before the license expires. Santhosh |
November 22, 2005, 06:57 |
And would you share this environment variable with us?
S.W. |
November 23, 2005, 05:54 |
Its,
ANS_FLEXLM_EXPWARN_DAYS = 'days' Santhosh |
Display Modes | |
Gambit and Fluent license error message | Dimitris | FLUENT | 11 | October 1, 2012 02:05 |
License Error | lffabiani | CFX | 2 | June 30, 2011 20:51 |
ANSYS License Error | vincentryan.s | ANSYS | 0 | June 7, 2011 15:31 |
installing ansys license | mr_aliagha | ANSYS | 3 | December 23, 2010 11:21 |
ansys 12.1 license error | clarkent | ANSYS | 5 | November 1, 2010 08:48 |
