how to draw a chart of energy (heat source) as a function of time in CFD-post (CFX)?
Like Tree3Likes
  • 1 Post By Gert-Jan
  • 1 Post By ghorrocks
Old   May 10, 2019, 03:29
Default how to draw a chart of energy (heat source) as a function of time in CFD-post (CFX)?
Hamda
Hamda is on a distinguished road
Since I have done an unsteady state simulation, I want to draw some charts to show the change of some parameters (e.g. energy source, temperature, Pressure,....) along the time, i.e. the X axis is time and Y axis is Temperature or pressure,..... But I don't know How.
in CFX, in solid domain, I wrote an expression for heat source in which the heat source is a function of time. Now in CFD-post I want to draw a chart of it as a function of time. I defined a variable called "power" and its is expression is the same expression that was defined in Pre CFX. But I still clouldn't draw a chart. Any ideas?
Many thanks
Hamda
Hamda is offline   Reply With Quote
Old   May 10, 2019, 05:02
Gert-Jan
Gert-Jan will become famous soon enough
You'd better create a monitor in Pre to monitor the value of your expression during the solving process. Much easier.
Now, in Post, you are looking at the result of the final timestep of the whole transient simulation. This file has no history. It is a snap shot.
This results file has links to intermediate results (trn-files), if you, beforehand, told CFX to save these. If so, you can load these trn files and recreate the heat source afterwards. But that can be hassle.
Hamda likes this.
Gert-Jan is offline   Reply With Quote
Old   May 10, 2019, 06:47
Hamda
Thank you for your response. well I wanted to create a monitor in Pre but I don't know how. I know how to create a monitor in fluent but in Pre no. I'll really appreciate if you guide me on this issue.
Many thanks
Old   May 10, 2019, 06:55
Gert-Jan
Output Control > Monitor> Option > Expression
Click on the sqrt(Alfa) sign to get a blank field. Then use your RMB to get several options which will guide you to your CEL expressions.
Hamda likes this.
Old   May 11, 2019, 03:44
Hamda
Thank you so much. By the way what is "RMB"?
Old   May 11, 2019, 06:33
RMB = right mouse button
Hamda likes this.
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 43 October 28, 2025 04:19
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
[foam-extend.org] problem when installing foam-extend-1.6 Thomas pan OpenFOAM Installation 7 September 9, 2015 22:53
Star cd es-ice solver error ernarasimman STAR-CD 2 September 12, 2014 01:01
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
