Using additional variable
Old   October 24, 2005, 15:00
Default Using additional variable
Tuks
Hi all,
I want to know whether i can use the additional variable concept for the problem i am solving. The problem is to simulate the bioreactor (two phase Liq-Gas system), but we are solving the single phase (only Liq) problem with gas phase replaced by free-slip wall. Here we need to account for the mass transfer tanking place through free-slip wall (i.e. liq-gas interface in actual practice).
The mass transfer of species leads to change in partial pressure ingas phase and intern may be liquid concentrations. And this process in function of time as well. I want to try the partial pressures of gas phase as addtional variables.
Thanks in advance Regards Tuks The partial pressures are varying with time. Can i use the algebric equations for additaional variables? The difficulty i am facing is the variation w.r.t time.
Old   October 25, 2005, 10:24
Default Re: Using additional variable
Mike
Additional Variables don't affect the flow, so you can't use this approach. You may be able to use a Boundary Source Term (in CFX-10), the difficult part is figuring out source terms to add to the appropriate equations. Mike
Additional Variable tav98f CFX 3 April 28, 2011 12:33
emag beta feature: charge density charlotte CFX 4 March 22, 2011 09:14
Problems with additional variable Krishna Premi CFX 1 October 29, 2007 08:19
Multi_component Vs Additional Variable Anurag CFX 2 February 4, 2005 16:45
Replace periodic by inlet-outlet pair lego CFX 3 November 5, 2002 20:09
