Transient: Domain Timescale Factor
Like Tree1Likes
  • 1 Post By Gert-Jan
Old   May 13, 2019, 13:08
Default Transient: Domain Timescale Factor
Erik
evcelica is on a distinguished road
Greetings all,
I'm doing a cool down simulation where It takes many days to cool down a geometry (295K down to 4K)
The fluids equations must be solved on a small time scale (~0.01s) where the solids can be solved on much higher timescales (100+ seconds). What I have been doing is freezing the fluids equations, then solving the energy equations @ 100+second timesteps. Using constant properties for the cool down gas. Unfortunately It seems the fluid balancing (there are 98 parallel routes) changes during the cooldown once temperatures start getting low.
So what I'm wondering is:
Can I use the domain solver control: Timescale Factor = 10000 for the solid domains during a transient simulation. The option is there, so I will test it to see what happens, and report back. Documentation seems to hint at Yes, but it is a bit unclear. CFX Pre Users Guide Section 13.4.10.1.
Would this be roughly the same as reducing the specific heat of the solid materials by a factor of 10000? Would Specific Heat reduction of the solids be an alternative option if the timescale factor does not work?
Approximate solution is fine, It should be better than my frozen fluid equations solution, which I can use for comparison.
evcelica is offline   Reply With Quote
Old   May 13, 2019, 19:48
I think your frozen fluids approach is probably the best one.
You cannot use time scale factors in transient simulations (to my knowledge anyway).
Note: I do not answer CFD questions by PM. CFD questions should be posted on the forum.
Old   May 14, 2019, 00:15
Opaque will become famous soon enough
It is effectively changing the thermal capacitance w/o messing around with the material details.
Opaque is offline   Reply With Quote
Old   May 14, 2019, 04:35
Gert-Jan
Gert-Jan will become famous soon enough
Originally Posted by evcelica View Post
Greetings all,
Do you do this manually? Or do you make use of Fortran?
Gert-Jan is offline   Reply With Quote
Old   May 14, 2019, 07:38
Erik
Thanks for the responses all,
So, reporting back, it does seem to work. Yes, the domain timescale factor works for the transient simulations (It is set in each domain). Results track along with with my frozen fluids approach.
It is much less efficient though, after an overnight run on 5 machines, it is only 1.3 equivalent hours into the 130 hour cool down. So It isn't practical in this case, and frozen fluids seems to be the best. (Quickest anyways.)
I do the frozen fluid equations manually: using the expert parameter: solve fluids = f.
What benefit would Fortran offer? I thought about if it would be possible to change this expert parameter every so often to true, to update the fluid field. I would have to change the time steps as well (much shorter) during this time, then increase again when solving only energy equations. I did this a few times on the fly in solver manager manually during the cooldown. Could that be automated?
Old   May 15, 2019, 04:02
Gert-Jan
In CFX-10.0 I had a fortran code which did this automatically. That can help you overnight.
The code was able to switch off fluids for a certain timestep so only energy and scalar were solved using a large timestep.
It was a buoyancy driven flow where the coupling was quite strong. So the allowable timestep increase when fluids were skipped was only a factor 3. Otherwise the flow would deviate too much.
Maybe in your case the coupling is less strong allowing a larger time step increase. I can share the old Fortran. Alternatively ask ANSYS for a more recent version.
evcelica likes this.
Old   May 15, 2019, 09:24
Erik
That sounds very interesting. My flow won't deviate too much. I would like to take a look at the fortran. I have never used fortran with CFX, so that will be new to me, but could prove very useful. Thank you, I'll PM my email.
Can CFX model periodic heat transfer problem Ethan_Sparkle CFX 41 June 14, 2017 08:22
Sudden increase the residual of Maxwell's equations hsezsz CFX 2 October 13, 2016 07:58
Setting rotating frame of referece. RPFigueiredo CFX 3 October 28, 2014 05:59
CFX domain comparison Kiat110616 CFX 4 April 3, 2011 23:43
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
