help! air viscosity versus pressure
Old   August 30, 2005, 15:23
Default help! air viscosity versus pressure
lin
Does anybody know the relationship between the air's viscosity and the pressure(0.1 to 10000 times of the atmosphere pressure)? Thanks a lot!!
Old   August 30, 2005, 21:52
Default Re: help! air viscosity versus pressure
Jeff
Look in Bird, Stewart, & Lightfoot, "Transport Phenomena". There's a correlation for monotomic gases (use nitrogen).
Also look in Perry's Chemical Engineer's handbook. I think there's a correlation in there for air as well.
Jeff
Old   August 31, 2005, 08:26
lin
Thank you Jeff!I am a graduate student in electrostatics field.Thank you for your information!I will give it a try.
Old   September 29, 2005, 17:44
Ryan
I don't have access to these books, can you post the correlation you found (if any)? I need viscosity vs. temp and pressure relationships for high pressure air.
Old   November 1, 2005, 15:12
Manmatha Kumar Roul
I want to know the variation of air viscosity versus pressure. Please help.
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
reversed flow at pressure inlet and turbulent viscosity is limited.... cfdiscool FLUENT 10 June 10, 2015 06:15
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Properties of air versus temperature AND pressure Vincent Main CFD Forum 5 July 28, 2008 06:28
help! air viscosity versus pressure lin Fidelity CFD 2 November 3, 2005 22:43
