CFX: Transient sim with fluid-fluid domain interface |
April 3, 2010, 11:44 |
Fidel Arzola
Rep Power: 16 |
Hello all,
I'm simulating a Kaplan hydraulic turbine. I got a good convergence in steady state, but I'm studying unsteady flows and of course is needed to carry out transient simulations. I'm using a fifth part of runner subdomain and a complete draft tube geometry (the water conduit to the exit), this is equivalent to said a pitch angle for side one equal to 72 degrees and a pitch angle for side two equal to 360 degrees. Then I can see a very good behavior of oscillations due to blade passage frequency in the outlet of the runner but it didn't pass to the draft tube subdomain . So, what's happens? From the draft tube point of view it's as the fifth part of runner is a total water passage way. Someone can give me a recommendation to try to solve it.
Thanks, Fidel |
April 4, 2010, 07:34 |
Rep Power: 143 |
Sorry, I don't understand your question.
April 6, 2010, 12:05 |
Bruno
Rep Power: 21 |
Fidel,
Did you remember to check the pitch change on the rotor-draft tube interface? That seems to be the problem. |
April 6, 2010, 12:07 |
Bruno
Rep Power: 21 |
Fidel,
From what you said you have two domain interfaces. Did you check the pitch change on both of them? |
April 7, 2010, 15:08 |
Fidel Arzola
Rep Power: 16 |
I'm setted a pitch change between rotor and draft tube equal to 72°/360° and a pitch change between distributor and rotor equal to 15°/72°. Is that correct?
Thanks, Fidel |
interface domains, pitch angle, transient simulation, turbine blade |
Can CFX do CHT simulations with a solid domain rotating in a stationary fluid domain? | acro | CFX | 15 | September 23, 2016 11:16 |
Pressure fluctuations along transient rotor-stator interface | Norbert | CFX | 4 | March 31, 2010 07:54 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
domain interface on CFX 11 | Rogerio Fernandes Brito | CFX | 1 | June 22, 2008 18:41 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
