Stereo Mode Error
Like Tree2Likes
  • 1 Post By SPRIN
  • 1 Post By Monslighter
Old   July 17, 2019, 01:54
Exclamation Stereo Mode Error
Subhash Prabhu
SPRIN is on a distinguished road
I switched ON 'Stereo Mode' in CFX>Eidt>Options>CFX-Pre>Viewer>Stereo. Now I am not able to open CFX-Post. I am getting an error as WARNING Stereo not available. Now I want to switch off the stereo mode. But I am not able to open CFX Post to change the settings. How to reset this.
arsenis likes this.
SPRIN is offline   Reply With Quote
Old   July 17, 2019, 02:14
M
AtoHM is on a distinguished road
I don't have a direct solution but you can try and ask CFX support about this.
Another option could be a user settings file. Many applications store user settings like view properties e.g. in config files. Maybe you can check the cfx installation folder(s) for such a file and see if there is some obvious line like "use stereo mode = True" or something like that. Always create a backup before editing such files.
AtoHM is offline   Reply With Quote
Old   July 18, 2019, 05:51
Subhash Prabhu
Thanks AtoHM. I have resolved the issue. I changed the variable as 'Mono' in C>User>.cfx>CFXPreferences - search for Stereo and replace with Mono
Old   May 5, 2020, 03:22
Arsenis Chatzimichailidis
arsenis is on a distinguished road
Just to add my experience from 2020R1:
I couldn't find "Stereo" or "Mono" in .cfx>CFXPreferences, so I deleted it and when opened CFD-Post, the folder was recreated and the annoying problem solved.
As always, exercise the file deletes with caution!
arsenis is offline   Reply With Quote
Old   August 19, 2020, 05:57
Mohsen
Mohsen Barsim is on a distinguished road
Thanks a lot for all participants for the valid query and a best solution
Mohsen Barsim is offline   Reply With Quote
Old   March 13, 2021, 21:41
Frichen
Monslighter is on a distinguished road
It's no use to change “Stereo” to “Mono” for my question, so i delete “Viewer Eye Point = Stereo”, and POST is opened successfully.
urosgrivc likes this.
Monslighter is offline   Reply With Quote
#stereomode
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries NickG OpenFOAM Installation 3 December 30, 2019 01:21
Errors in UDF shashank312 Fluent UDF and Scheme Programming 6 May 30, 2013 21:30
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 08:24
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
How to get the max value of the whole field waynezw0618 OpenFOAM Running, Solving & CFD 4 June 17, 2008 06:07
