Is there a way to know what equations is being used in a case? |
August 3, 2019, 18:35 |
Lucas
Rep Power: 6 |
Hi there, I am new in CFD and I am studying it by myself. And I have some questions.
I know that I can look at the theory guide and try to relate the options to the equations. But Is there a simple way of doing it? Also I am confused with adding source terms and others expressions. If I looked at the literature and saw a set of equations that I should use, how can I know make the relation between the variables which are already avalaible in CFX and expressions I need to add? I'm reading the tutorials to see if I understand how to make the relations I mencioned above, but so far, I couldn't understand. Thanks in Advance Luan |
August 3, 2019, 23:12 |
Rep Power: 143 |
The documentation is the only place you will find what the underlying equations are.
Source terms - you just have to match up the variables and derive expressions for ones which are not available. Again, there is no shortcuts.
August 4, 2019, 02:43 |
Lucas
Rep Power: 6 |
Thanks a lot!
August 20, 2019, 10:19 |
Lucas
Rep Power: 6 |
Ghorrocks, the available mass transport equation available in CFX is the continuity equation? This is what a could understand from the documentation. If I want to simulate a mass transfer I ought to add mass source terms to the continuity equation? I am reading the documentation, but I am lost in adding the source terms.
August 20, 2019, 13:39 |
Rep Power: 32 |
A description is key here. The word mass transport is used in many contexts; therefore, it is not clear what you are trying to achieve.
Since you already have a set of equations in mind from some publication, post the equations you would like to solve and here we can try to guide on how those equations are presented in ANSYS CFX. |
August 21, 2019, 10:15 |
#6 | |
Lucas
Rep Power: 6 |
I am modelling a 3D adsorption which have different equations that could be used. In the adsorption I have a packed bed which is percolated by multicomponent fluid. 1. (see the attachment) The mass balance equation in CFX documentation doesn't have a source term (the whole equation is equal to 0). I created a variable composition mixture of gases to be my multicomponent fluid, the equations CFX will use to solve are similar to those attached? I will associate the specific aspects of adsorption using the source term of the mass balance equation. The equation for the momentum balance is clearer. I am reading the documentation, but I couldn't figure out this aspect of the problem. |
August 21, 2019, 11:58 |
Rep Power: 32 |
Based on those equation, check the documentation and tutorials for "Multicomponent Flow".
Learn how to create a variable composition mixture material Select that material as your fluid at the domain level add the diffusion coefficient for each material component (recall diffusion in the mixture) Set the proper boundary conditions for the material components at inlets if any. Unfortunately, ANSYS CFX only supports zero flux boundary condition at walls. Your description does not show with boundary conditions you require. If the material components are just transported by the flow, and diffused, you should be fine at this point. If material components are generated, or consumed, the you need to set a reaction mechanism describing such process. Hope you can move forward with the above information. Let us know how it goes. |
August 21, 2019, 12:38 |
Lucas
Rep Power: 6 |
Thanks for the help!
With adsorption one of the components will be "consumed" by the surface of the porous solid as the flow percolates it. I read the tutorial reacting flow in a mixture tube. But tua tutorial doesn't explain the connection between the sources created to the equations that are available by default um CFX. If CFX has the governing equation that I want to add. Are there a variable name by default which I have to use (for momentum, mass and energy governe equations)? I've already looked at CFX-pre guide. |
August 21, 2019, 18:23 |
#9 |
Rep Power: 32 |
The active equations are presented in the Domain panel:
For a fluid/porous domain: - the continuity and momentum are active by default. - you must decide if the energy equation is needed (I guess it is for your case), and select the appropriate model, Thermal or Total (read the documentation guidelines) - The continuity for the species are presented as Component Details, and you must select a ballast/constrain material. See the panel for details, and set Diffusion coefficient appropriately. By now, you should be set with the equations in the interior. For the adsorption at the boundary, open the boundary panel and set a boundary mass source/sink using the continuity equation listed there. The panel will guide you through what data is required. You should know how the adsorption depends on other parameters and determine the adsorption rate. |
August 22, 2019, 09:38 |
#10 | |
Lucas
Rep Power: 6 |
Soon, I'll post my results. |
September 9, 2019, 10:22 |
#11 |
Lucas
Rep Power: 6 |
Is it possible to add a source term to the continuity equation in ANSYS CFX? In solver theory guide the continuity equation is set to be equal to 0, but in some papers related to phenomena I want to model, the continuity equation is set to be equal to a mass source term.
September 9, 2019, 10:33 |
#12 |
Rep Power: 32 |
Check the documentation for sources
There is a way to add sources to continuity equation, which automatically adds the contribution to the other equations as well. |
October 15, 2019, 11:31 |
#13 | |
Lucas
Rep Power: 6 |
Thanks in advance Last edited by lordluan; October 15, 2019 at 11:45. Reason: I edited because I found a possible answer to my question |
Dual-Element Front Wing Case Using SST K-OMEGA TURBULENCE MODEL | Jesus.M | OpenFOAM Running, Solving & CFD | 1 | December 14, 2020 13:48 |
Reporting a bug in Allrun script on wingMotion case | i.sabahi | OpenFOAM Bugs | 0 | June 10, 2018 09:00 |
Simple channel case using cyclicAMI will not converge | cbcoutinho | OpenFOAM Running, Solving & CFD | 3 | August 4, 2015 12:28 |
CFD Post - How to check for case in an expression | pilakin | ANSYS | 0 | September 26, 2014 04:44 |
Transient case running with a super computer | microfin | FLUENT | 0 | March 31, 2009 11:20 |
