October 9, 2005, 07:32 |
torque calculation
hello everyone, the calculator in the CFX post is not able to calculate the torque for a specific result file. how to calculate torque using expressions in cfx post. can anyone help me... thank you
October 9, 2005, 20:00 |
Re: torque calculation
What exactly are you trying to calculate torque on?
-Robin |
October 10, 2005, 02:51 |
am trying to calculate torque on a blade rotating abt x-axis. by the way what happened to forum at waterloo.ansys site.
October 11, 2005, 13:23 |
The CFX Forum was down for a few days due to server problems. It is back up now.
More specific to my question, are you trying to calculate torque on a surface or volume? The torque calculation will not work on a volume. Regards, Robin |
October 11, 2005, 15:44 |
i need the torque to be calculated for surfaces only. actually some functions(mass flow, massflow ave,torque) are not working for this specific result file. full(all) variables are written to the result file. may be some bug since the file is large. so i need to know how the torque can be calculated (in my case for the surfaces rotating about x-axis- to be particular). regards sudhakar
October 12, 2005, 10:58 |
Hi Sudhakar,
It's possible the resutls file is incomplete. You could define an expression to integrate the torque instead by calculating the local Z and Y components of force times the radius. ty local = Pressure * Area Z * Y tz local = Pressure * Area Y * Z Torque on Blade = int(tz local + ty local)@blade Regards, Robin |
October 13, 2005, 11:02 |
thanks Robin. But am not able to use that integral function in CEL. It gives some syntax error. so what is the syntax to use integral function -regards sudhakar
October 13, 2005, 17:00 |
Sorry, that should have been sum() not int().
-Robin |
October 14, 2005, 08:36 |
#9 |
Thank you Robin. I checked the expression for a result file(centrifugal pump) where i was able to calculate the torque using the calculator. but the value (for one blade surface) that i get using the expression is double than that i get from the functional calculator. is there anything wrong in the torque expression procedure i follow...my case is a centrifugal pump rotating abt x axis tylocal = Pressure * AreaZ * Y AreaZ = Area * Normal Y Similarly tzlocal = Pressure * AreaY * Z AreaY = Area * Normal Z
Torque on blade = sum(tylocal+tzlocal)@bladesurface |
October 14, 2005, 09:33 |
#10 |
Area Z = Area * Normal Z Area Y = Area * Normal Y
October 15, 2005, 11:17 |
#11 |
then too the value is about twice of the value got from the functional calculator.
October 17, 2005, 10:35 |
#12 |
Hi Sudhankar,
I just checked on one of my results files and the answers nearly match (there will be a slight difference, since the torque calculation uses the integration point values). My expressions are: EXPRESSIONS: Area Z = Area * Normal Z Area Y = Area * Normal Y ty local = Pressure * Area Z * Y tz local = Pressure * Area Y * Z Torque on Blade =sum(tz local + ty local)@BLADE END If you still see a difference, make sure your expressions are correct for your axis of rotation and that your regions are the same. Regards, Robin |
November 11, 2005, 07:04 |
#13 |
dear sir
please the details regarding the torque calculations for Dc motor and all other related issues thanking you ravinandan |
December 9, 2005, 02:34 |
torque calculation
#14 |
dear sir
please send the details regarding the torque calculations for Dc motor and all other related issues thanking you. |
December 19, 2005, 06:38 |
#15 |
How to calculate the torque for all applications. methods
January 5, 2006, 10:08 |
#16 |
we are the manufacturer of orbital shaker.we had problem to select a ac motor for our application.our requirement listed below. speed reduction ratio:1:4.how to select a motor whether based on torque or rpm requirement?
Display Modes | |
torque calculation to find efficiency of fan | bhanu1810 | STAR-CCM+ | 5 | September 2, 2015 04:58 |
Torque calculation of 2D VAWT Wind Turbine | Anonymized_JL1 | FLUENT | 14 | September 26, 2013 04:35 |
torque calculation | mach000 | CFX | 2 | April 14, 2010 05:00 |
Torque calculation in pumping equipment | Kirill | Main CFD Forum | 0 | June 26, 2007 17:59 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 05:41 |
