Exporting data to Excel
Old   January 23, 2006, 19:27
Default Exporting data to Excel
PetrK
Hi, I need your help. I created in Post a polyline (section of a wall and a plane) and I need to export pressure data on this curve. The problem is, that some values in the exported .txt file are appeared two times or three times. I know, it's a different nodes, but I need to clean it before export. Any suggest? Thanks PetrK
An Example: X [ m ] Pressure [ Pa ] 0.588894 2415.98 0.588894 2415.98 0.585803 2009.12 0.585803 2009.12 0.578629 1239.58 0.578629 1239.58 0.578629 1239.58
Old   January 23, 2006, 21:44
Default Re: Exporting data to Excel
TB
I bet you are specifying a polyline using a couple of points. Duplicate data may occur at these connecting points. If you really need to get rid of this, I'll suggest creating a series of lines with small gaps in between and then dump all the data in a single file. If you're plotting Pressure Vs X in Excel, duplicate data don't matter as they have same values on that point.
Old   January 24, 2006, 08:54
PetrK
Thx for reply, I founded the better way - you can simply apply an filter in MS Excel
Exporting data (cell values, ascii) and obtaining more data than cells! TfG FLUENT 3 April 3, 2015 00:18
Exporting data from simulations netmaster STAR-CCM+ 2 May 10, 2011 12:45
Exporting data to MATLAB Ryan FLUENT 2 July 12, 2006 06:41
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 17:27
exporting data sourav FLUENT 2 August 16, 2005 15:05
