Anyone know the use for 3-D curves
Old   January 3, 2006, 12:13
Default Anyone know the use for 3-D curves
Richard
In designModeler, There is a option--3-D curves. What is it used for. Is it possible we use it to generate blade profile?
Old   January 3, 2006, 14:04
Default Re: Anyone know the use for 3-D curves
Jianping
In my view, if your blade has a curved shape it would be easier to use a third party CAD tool (eg. solidworks).
Best regards!
Jianping
Old   January 3, 2006, 16:53
Andrew
I have to agree... I spent hours trying to generate a blade profile (NACA 0012) using 3d curves. In the end I used solidworks and imported it into design modeller as a step file, taking all of 15 minutes!
Old   January 4, 2006, 00:49
Richard Teo
But I do not know how to use solid work. Is it easy to learn?
Old   January 4, 2006, 02:03
TB
Workbench is still at its earlier development. Don't think it's a good substitute for CAD at this stage. I don't use it at all.
Old   January 31, 2006, 21:29
Default Re: Anyone know the use for 3-D curves *NM*
Richard
Old   January 31, 2006, 21:35
Richard
what type of format you savs as using solid work. I currently using PRO-E to generate the curve and save them as IGES and SAT. The importing to CFX is OK; but once i get to meshing, CFX keep giving me warning that I should redo the geometry due to poor parmetization, small internal angle etc. Please help.
problem with surface creation in ICEM from multiple curves dialolema ANSYS Meshing & Geometry 2 October 27, 2014 13:14
P-Q Curves in CosmosFlow linsir0825 Main CFD Forum 0 May 23, 2011 02:47
[ICEM] Coarse mesh nearer to curves jsm ANSYS Meshing & Geometry 8 September 17, 2009 07:07
How to remove yellow curves Prateek jain CFX 4 June 11, 2007 23:09
color curves Le Stanc CFX 0 December 5, 2006 07:12
