UDF for particle interception with pt_termination fortran routine |
July 23, 2015, 10:52 |
Rep Power: 11 |
Hey,
i try to simulate a Filter with a complex geometry. For that I need the Interception of particles. The particles must have a Volume for that (not only being a mass point). The Particle meets the filter a radius before it's mass (middlepoint).This means, that particles get stuck on the filter wall, if they come closer than their radius. I hope you know what I mean. I think I can realize that with the user fortran routine pt_termination from the Ansys fortran examples. I first tried it on a sphere (based on a udf here from the forum): thats possible. Here I have die coordinates of the sphere. But for my real geometry I have no coordinates/ can't give it a radius. Now I had the Idea: can I refer it to the boundary condition of my geometry, The wall of the filter??? For the sphere the code looks: ... Particle fate : RET(1,1) C C Argument variables C ------------------- C C Particle mean diameter : ARG(1,1) C Particle position : ARG(1,2:4) C Sphere x-position : ARG(1,5) C Sphere y-position : ARG(1,6) C Sphere z-position : ARG(1,7) C C We know that NLOC is 1 for the particle user source routines!!!! C================================================= ====================== C C----------------------------------------------------------------------- C Calculate the return variables C----------------------------------------------------------------------- C CALL USER_FATE (RET(1,1),ARG(1,1),ARG(1,2),ARG(1,5),ARG(1,6),ARG( 1,7)) C END SUBROUTINE USER_FATE (FATE,DIA,PPOS,CPOSX,CPOSY,CPOSZ) C C --------------------------- C Preprocessor includes C --------------------------- C #include "cfd_sysdep.h" #include "cfd_constants.h" C C ------------------------------ C Argument list C ------------------------------ C REAL FATE, DIA, PPOS(3), CPOSX, CPOSY, CPOSZ REAL sphereRAD, PRAD REAL CONTACT C C ------------------------------ C Local variables C ------------------------------ C REAL DEAD, ALIVE C ------------------------------ C Executable statements C ------------------------------ C DEAD = 0. ALIVE = 1. C sphereRAD = 0.001 C C---- Particle starts as alive C FATE = ALIVE C C---- Calc particle radius PRAD = ((CPOSX-PPOS(1))**2 + (CPOSY-PPOS(2))**2 + (CPOSZ-PPOS(3))**2)**0.5 CONTACT = sphereRAD - (PRAD - DIA/2.0) C C---- Check if user defined criterion was exceeded, stop particle C --> Set particle mode to __dead__ C IF (CONTACT.GT.0.0) THEN FATE = DEAD ENDIF C END But can I really refer it to the boundary condition. I always get an error. Here is the changed code (the changes are bold): ... INTEGER NARG, NRET, NLOC C CHARACTER*(4) CRESLT C REAL ARG(NLOC,NARG), RET(NLOC,NRET) C INTEGER IZ(*) CHARACTER CZ(*)*(1) DOUBLE PRECISION DZ(*) LOGICAL LZ(*) REAL RZ(*) C C================================================= ====================== C C --------------------------- C Executable Statements C --------------------------- C C================================================= ====================== C C Return variables: C ----------------- C C Particle fate : RET(1,1) C C Argument variables C ------------------- C C Particle mean diameter : ARG(1,1) C Particle position : ARG(1,2:4) C USERREG x-position : ARG(1,5) C USERREG y-position : ARG(1,6) C USERREG z-position : ARG(1,7) C C We know that NLOC is 1 for the particle user source routines!!!! C================================================= ====================== C C----------------------------------------------------------------------- C Calculate the return variables C----------------------------------------------------------------------- C CALL USER_FATE (RET(1,1),ARG(1,1),ARG(1,2),ARG(1,5),ARG(1,6),ARG( 1,7)) C END SUBROUTINE USER_FATE (FATE,DIA,PPOS,CPOSX,CPOSY,CPOSZ) C C --------------------------- C Preprocessor includes C --------------------------- C #include "cfd_sysdep.h" #include "cfd_constants.h" C C ------------------------------ C Argument list C ------------------------------ C REAL FATE, DIA, PPOS(3), CPOSX, CPOSY, CPOSZ REAL USERREG, PRAD REAL CONTACT C C ------------------------------ C Local variables C ------------------------------ C REAL DEAD, ALIVE C ------------------------------ C Executable statements C ------------------------------ C DEAD = 0. ALIVE = 1. C USERREG = area@Wall C---- Particle starts as alive C FATE = ALIVE C C---- Calc particle radius PRAD = ((CPOSX-PPOS(1))**2 + (CPOSY-PPOS(2))**2 + (CPOSZ-PPOS(3))**2)**0.5 CONTACT = USERREG-(PRAD-DIA/2.0) C C---- Check if user defined criterion was exceeded, stop particle C --> Set particle mode to __dead__ C IF (CONTACT.GT.0.0) THEN FATE = DEAD ENDIF C END Do you know where my mistake is, if it would be possible? Thank you very much for your help. Last edited by abcdefgh; July 27, 2015 at 04:42. |
July 23, 2015, 11:11 |
Rep Power: 32 |
USERREG is unset, i.e. it is not initialized or evaluated anywhere in the shown code.
July 23, 2015, 11:17 |
Rep Power: 11 |
Is that not enough? "USERREG = area@Wall"
What and where would you write? And do you think its possible to refer it to the wall? |
July 23, 2015, 11:19 |
Rep Power: 32 |
The line is commented out, and the syntax is invalid anyways.
July 23, 2015, 11:23 |
Rep Power: 11 |
Oh yes, you're right. Thank you very much.
hm...how else can I write it? Only 'Wall'...areaAve()@Wall...!?! I have to say 'wall' is my boundary called in the setup. |
July 27, 2015, 04:40 |
Rep Power: 11 |
I'm Sorry, but I didn't find the solution yet.
How can I write instead of sphereRad (see the part of the user Fortran) C DEAD = 0. ALIVE = 1. C sphereRAD = 0.001 C C---- Particle starts as alive C FATE = ALIVE C C---- Calc particle radius PRAD = ((CPOSX-PPOS(1))**2 + (CPOSY-PPOS(2))**2 + (CPOSZ-PPOS(3))**2)**0.5 CONTACT = sphereRAD - (PRAD - DIA/2.0) C The Problem is, I have no Geometry like a cylinder, thats why I have no Radius. Is it possible to refer it to the boundary condition, the wall of the Filter? What is a valid syntax for that? Thank you for your help! |
October 6, 2019, 13:30 |
surya
Rep Power: 10 |
hey,
did you have a udf for interception part? |
Comparison between C/C++ and Fortran? | rick | Main CFD Forum | 45 | September 6, 2011 00:52 |
Fortran routine for advection-convection equation | khan | Main CFD Forum | 3 | May 23, 2007 13:08 |
Fortran 90 faster than C/C++ | B. R. Guirguis | Main CFD Forum | 48 | March 6, 2006 13:49 |
Particle Injection User Fortran Routine | Adam | CFX | 5 | December 13, 2005 03:16 |
FORTRAN Routine - variable passing | Malcolm | CFX | 1 | August 11, 2005 18:51 |
