February 3, 2006, 03:36 |
help for CFX solver
I got this error messenge while running the solver. Pls help. Any suggestion is welcome.
ERROR #001100279 has occurred in subroutine ErrAction. | | Message: | | *** Run-time memory configuration error *** | | Not enough free memory is currently available on the system. | | Could not allocate requested memory - exiting! | | |
February 3, 2006, 04:46 |
Re: help for CFX solver
The message is quite clear, isn't it? It means that you have insufficient memory in your machine to run your problem.
Change memory allocation factor Default value in Solver to higher value e.g 1.1 or 1.2. If problems still exist, consider upgrading your hardware or reduce the size of your meshes (just for initial run). Do a quick search for previous post in the forum. Plenty of tips for such problem. |
February 7, 2006, 01:08 |
TB,
Why do you feel the need to be sarcastic? I've read a few of your posts, and I think your attitude is uncalled for. If you are annoyed by the posters, go elsewhere. |
February 7, 2006, 17:31 |
It did not look sarcastic to me. I think TB's post was sensible and helpful. Glenn Horrocks |
February 7, 2006, 22:23 |
Hi.... You're a bit sensitive. I find a lot of useful information by doing some search over previous posts and it saves me time. I know some guys here aren't aware of this search feature. Nothing wrong about pointing this out.
A New Solver for Supersonic Combustion | nakul | OpenFOAM Announcements from Other Sources | 19 | February 27, 2024 09:44 |
[Other] A New Solver for Supersonic Combustion | nakul | OpenFOAM Community Contributions | 20 | February 22, 2019 09:08 |
thobois class engineTopoChangerMesh error | Peter_600 | OpenFOAM | 4 | August 2, 2014 09:52 |
Development of a Low mach PISO solver | nishant_hull | OpenFOAM Programming & Development | 0 | August 25, 2009 12:48 |
why the solver reject it? Anyone with experience? | bearcat | CFX | 6 | April 28, 2008 14:08 |
